Question about Harmon Kardon Harman Kardon Hk 3390 High Performance 2 X 80w Stereo
HK3390 only Right Speakers working Not Left Swapped Speakers and they work
I have Speaker 1 and Speaker 2 set up. The Right Speakers work on both the left ones do not.
2 Suggested Answers
Good User
  • 87 Answers
SOURCE: Left speaker is very quiet
This may be a capacitor problem, evaluate and replace if bad.
Posted on Feb 12, 2014
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
I only have left channel on speakers working have tested speakers ok, swapped pre amp boards still one channel, swapped output boards the same. What could it be? Barry
is there Sound stage output is stereo if stereo then one side is missing or broken link from ic to speaker, If mono output then use with one side 2 speaker parallel.
May 20, 2015 | Audio Players & Recorders
I just picked up a JVC r33 receiver. Only three speakers work both left and right B speakers work. And only the left A speaker works. IS there a web site to trouble shoot?
Try one of the speakers that you know works in the left B to see if it works. If it does, then you know you have 1 dud speaker which could be only a broken wire or bad connection. If the good speaker doesn't work, try checking all the connections and balance positions to see if the speaker left B output is actually set correctly.
Apr 08, 2015 | JVC Audio Players & Recorders
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
Front-Right Speaker Not Working
I would have a look inside, it might be a bad soldering joint that got disturbed in the move. When you get inside follow the wires from the Front-Right terminal.
Apr 05, 2010 | Sherwood RVD-8090R Receiver
Only one speaker working - acer computer speakers
1 step: kindly check the connection of the left speaker if it is plugged to the right speaker properly.
2 step: Then check the balance under volume control if it has been set in the middle.
3 step: If possible check the speaker on some other device(cd player etc) other than your pc and see if the left speaker still doesn't have any sound.
if so kindly replace them
Jan 27, 2009 | Acer (90.18612.36B) Computer Speakers
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Harmon Kardon Harman Kardon Hk 3390 High Performance 2 X 80w Stereo Logo
16 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Lawrence Oravetz
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
