Question about Polder Slimmer Digital Scale
Sohnle round mechanical bathroom weighing scale
Diagram to set the 4 levers & clips for correct assembly of digital mechanical bathroom weighing scale
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
The weight jumps around. If I get off the scale and on again, the weight changes by 5 pounds. I am sure neither weight is correct.
You're only suppose to weigh yourself once a week. Make sure you're doing it after you've gone to the bathroom in the morning and with no clothes on. Other than that, I'd make sure the floor you set the scale on is level and that you are holding very still while weighing.
Feb 28, 2010 | Conair WW60 Weightwatchers Scale
I want to repair lab balance of mettler make collge model capacity 210 gm
sir i have top loading denver balance (210) it is out of working .First it given wrong wt after it some burnt smell come and after some weeks its display wanished
Jan 22, 2010 | Siltec Electronic Weighing Digital...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
My weighing scale is not working
try checking the battery and installing a new one
Jan 12, 2010 | Soehnle Linea Quattrotronic Digital...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Polder Slimmer Digital Scale Logo
Top Polder Home Experts
john h
Tom Chichester
Are you a Polder Home Expert? Answer questions, earn points and help others
