Wiring for sentry RX1E receiver - Televison & Video
We received a sentry v260 but do not have a combination for it. there is a key but does not work. reset batteries but dont have original coed. we are goodwill industries in redwood city,ca phone is...
The only way to get the combo is to contact sentry at the link below. Copy and paste it to your toolbar.
https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
Aug 25, 2011 | Sentry Fireproof Safe
SENTRY SO500 will not release and open. Combo is correct
From the Sentry Safe web site:
In order for Sentry Group to release a combination for any safe, we require a notarized request, stating that you are the owner of the safe (the last name of the notary public must be different than that of the safe owner). Please indicate how you'd like to receive your combination.Options include first class mail, e-mail or fax.Your letter must clearly indicate which method you are choosing to receive your combination, as well as the mailing address, e-mail address,or fax number to which it should be sent.Note that failure to indicate the method in which your combination should be returned to you will result in delays to the process.Please include the model number, serial number, and a $20 check or money order (please do not mail your credit card number), your address and telephone number.
Your request may be mailed to us at:
Sentry Group
Attn: Dept. 200 882 Linden Avenue
Rochester, NY 14625-2784
Please allow 7-10 business days, upon receipt of your request, to receive your combination.
This request may be faxed to us at : 585-381-2940.
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $20* money order on your fax (please allow 24 hours for processing your faxed request).
To pay by MasterCard or Visa please contact our Customer Service Department at 1-800-828-1438 (please do not fax your credit card number).
* Prices subject to change
Jan 29, 2011 | Sentry Fireproof Safe
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
I think i just wasted $18 on FixYa
Go to www.sentrysafe.com and download the: LOST COMBINATION OR SECURITY KEY NOTARIZED FORM
Complete the form, have it notarized and fax it to: 585-381-2940. A customer service rep will call in about an hour to get your credit card info. It will cost $20. You will receive the combination by e-mail shortly after that.
After you have the combination, you can go back to Sentry's website and register you safe and combination. In the future you can retrieve the info for free.
You can also mail the form with a check.
Sentry's telephone number is: 1-800-828-1438
Nov 11, 2010 | Sentry Fireproof Safe
2000 neon check engine light is on
P1685 Skim Invalid Key.
The Sentry Key Immobilizer Module contains a Radio Frequency (RF) transceiver and a microprocessor. The SKIM transmits RF signals to, and receives RF signals from the Sentry Key transponder through a tuned antenna ring integral to the SKIM housing. When the ignition switch is turned to the On position, the SKIM transmits an RF signal to the transponder in the ignition key. The SKIM then waits for an RF signal response from the transponder. If the response received identifies the key as valid, the SKIM sends a valid key message to the PCM over the PCI data bus. If the response received identifies the key as invalid, or if no response is received from the key transponder, the SKIM sends an invalid key message to the PCM. The PCM will enable or disable engine operation based upon the status of the SKIM messages.
you can look it up here:
http://www.engine-light-help.com/check-engine-light-domestic.html
Sep 13, 2009 | 2001 Plymouth Neon
We forgot the combination to our Sentry Fire Safe Model 1610 HELP
Contact SENTRY
Sentry Group
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $15* money order on your fax (please allow 24 hours for processing your faxed request).
Jul 31, 2009 | Sentry Fire-Safe Media File - SEN6720
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Oct 19, 2008 | Sentry Fireproof Safe
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
