Question about Sub-Zero 642
Refrige is 48 and freezer is 0 model 532 - Sub-Zero 642
  • stevejgarner May 23, 2009
    Same problem refrige side is 48 and freezer is zero, ice is forming on back wall of refrige side left side just below middle
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
Posted on Jun 27, 2015
  • 26 Answers
Spunds like you have a freon leak. Remove the back wall panel and look at the coil. Is the coil evenly frosted? If not you have a freon leak.
If the refrig. is less than 12 years old, it could still be under Sub Zero warranty for the seal unit.
Posted on May 25, 2009
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
The Refrigerator isn't cooling. The Freezer works fine. There is ice build-up in the drain resulting in a drip inside the refrigerator. After being thawed, it re-iced within 48 hours. The fan is...
Due to the blocked drain it sounds to me as if the vents in the ceiling of the refrig. has frozen over so no air can be circulated from the freezer into the refrig. section. This tip i wrote will show ya how to clear the drain and addation to clearing the drain the ice build up would need to be removed from the vents. Here is that tip, http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 23, 2011 | Kenmore Top Freezer Refrigerator
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Refrigerators Logo
342 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
