Question about Water Heaters
Tankless water heater not giving hot water
Electrician tested and all electrical is working, water is running thru the unit but not heating.
    Problem Solver:
  • 17 Answers
Call the manufacturer tech support. There are many things that can cause this. I have had 3 with failed circuit boards. They mail you a new one and it is now too hard to install.
Posted on Dec 31, 2013
SOURCE: Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Posted on Apr 22, 2009
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
  • 6 Answers
SOURCE: Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Posted on Jun 10, 2009
  • 11 Answers
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: Paloma PTG 74PV N1 Tankless Water Heater - stops heating
Most likely problem is the remote control not the main board. A safe temporary fix is to unplug the heater from the 110 volt outlet, remove the two low voltage wires from the remote control and use a small wire nut to connect the two conductors together. Plug the heater back into the 110 outlet and the heater should work just fine. The default water temperature is about 118 degrees at the heater. Replace the remote control ASAP.
Posted on Aug 03, 2009
I have c7 code
it is a communication problem between remote control and tankless unit
Temporary fix:
1 Turn off electricity to tankless and remove cover. Find two terminals that remote control connects to.
2 Disconnect remote control wiring. Turn electricity back ON.
3 Open hot water tap and see if unit works as expected.
4 Without remote, tankless will heat water to default 120 degrees F and will run without the remote.
Contact Rheem they may send you another pcb board.
Nov 11, 2013 | Rheem Paloma Tankless Water Heaters...
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
There is power to the system but when you turn water on elements do not come one and heat water. all phases have 238 volts to them. why will system not turn on and heat water
Do you have 3-phase water heater? Is this balanced or unbalanced 3-phase unit. Add comment and describe product in detail, including brand since i have some service resources for both types.
Or do you have ordinary residential split-phase 240Volt Bosch tankless computer that heats water, and has 2 or 3 separate elements, and a separate circuit breaker supplying power to each element? And testing across both hot leads coming from each breaker yields 238Volt?
Copy following link for Bosch tankless manuals, with brief troubleshoot section that does not provide detailed service procedures for repairing tankless computer:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
If this is new water heater, then call installer. If you installed yourself, then remove tankless and return to seller for refund.
Tankless computers require certain amount of water flow to activate computer sensors. Turn on Hot tap and listen to pipe to hear if water if flowing through hot pipe. Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter usually located just above where cold water connects to unit.
Delime tankless ... and use water softener. Tankless cannot be exposed to more than 11 grains hardness in water, or parts will fail within 2-3 years. Simply deliming tankless heat exchanger each year will not maintain full efficiency... although for typical family of 4, tankless comper water heater costs $100 more to operate than tank-type heater according to manufacturer's promo literature and independent studies.
Call local technician who specializes in fixing tankless computers. For plumbing problems call local plumber. These are two different things.
If tankless computer is older, then cut losses, and buy tank-type electric water heater at Lowes for $285 and make quick changeover and have hot water same day. Sell old tankless on ebay and cheat next guy, or sell at scrapyard for $3 per 100.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
Aug 03, 2013 | Powerstar Water Heaters
I've got the Bosch AE 9.5 tankless water heater.
1) Cheapest and most reliable solution: Install tank-type electric water heater from local box store for $250. Get store coupons, offer 10% off store price. Repairs are made same day with generic off-the-shelf parts.
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
2) Install grundfo water pressure boosting pump.
http://www.ronhazelton.com/projects/how_to_increase_water_pressure_in_your_home
http://waterheatertimer.org/How-to-solder-pipes.html
3) Remove areators and low flow shower heads, Maintain unit as shown in product manual: Delime tankless unit yearly, Clean water filter monthly.
4) Call city and report low pressure and report issue as fire hazard, move to different apartment. Call apartment complex and ask why they didn't read flow requirements for tankless before installing tankless.
5) Call Bosch 866-330-2729 and complain that nobody read the flow requirement or tested local water flow before installing tankless.
Dec 30, 2012 | Water Heaters
Electical connection for ru98e
Rinnai RU98e is gas water heater with .4 gallon per minute activation.
This tankless gas water heater plugs into ordinary 120Volt 60 Hz outlet and consumes 63 watts when running.
For electric tankless:
Copy following links for illustrated walk-thru and wire-breaker size calculation for electric:
Oct 31, 2012 | Rinnai Water Heaters
No hot water!! For some reason it is not heating the water!?
is the heating element still good. Was it on when no water was running thru it?
Jan 25, 2011 | Stiebel Eltron DHC-E 10 Electric Tankless...
I want to build a tankless hot water heater. does anyone have any plans for this?
go to rinnai web site they have all the descriptions of what is there and how it is together, i hope this helps you out in your venture
May 16, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Temperature Fluctuates
no the tub faucet is the only faucet that is wide open you might have to not run full blast on the faucet , your tankless water heater is under sized for the application, to many gallons per min going thru the unit, look at the rating chart for your unit, the r94 is only 9.4 gallons per min, and a tub faucet can be upto 5 gallons per min, depending on the faucet,,
Jan 16, 2009 | RTO American Heat Tankless Electric Water...
Water Heaters Logo
24 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
