Question about Philips 42FD9932 42 in. Plasma Television
42FD9932/17G Philips Plasma Issues (2 TV's)
So I've read a lot here on this particular TV and problem, but could use a lil more help.
I have a pair of these, each doing virtually the same thing.
Both will turn on, then hit power on remote, green LED, then right as the screen tries to come up, breakers click on the PSU and it switches back to red. (One switches to blinking red and I have to cycle the power switch before it'll come back, the other solid red and I can just hit power on remote again to bring back up.) I tried swapping PSU's, and rear/front assemblies in different orders.... results are the same.
So does this sound like it's strictly in the PSU? Or are the breakers trippin cause of something else?
I took some pics of the PSU maybe to help identify which Caps need replacement? All over this board is discussion of replacing the caps to fix the problem....
Haven't bought the service manual yet, I hate it when companies no longer support an item then wana charge you for the service manual. bogus.
Anyway, I'd like to get the pair back runnin. Thanx for any help
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
50 inches LG PLASMA TV TURNS OFF AFTER 15 MIN.
A blown capacitor might not be the reason. After 15 to 20 minutes of work, the temperature inside the set do rises much, this kind of fault can occur. Check its cooling fans.
Jun 25, 2013 | LG 50PT350 50 in. Plasma TV
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 43pp92 blue will not converge
You have a $ decision---this model uses two STK-392-120 convergence IC's--if it will not adjust one is bad.
Both need to be replaced--you can buy a pair on Ebay for less than 14 dollars plus shipping. Sometimes there will be a bad resistor near on of the chips that also needs to be replaced--this is a very common problem in rear projection TV sets--I have repaired hundreds of sets with this problem.
If you cannot do the repair yourself shop around your area--most shops charge about 300 for a repair like this on your set-I do lots of them here for 200 total.
If the $ cost does not make sense--it is time to buy a new TV--but remember this kind of set has a lot less problems than LCD or Plasma TV sets.....
If you have any questions or need more information let me know--I am here to help people.
Regards, SD TECH
Oct 07, 2009 | Philips 43PP9202 43" Rear Projection...
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips Plasma 42" - constant purple haze
if the set is less then a year old it may be under factory warranty.
it sounds like the vscan, vset , or vsus voltages are off..it could also be the panel itself..contact philips
Nov 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42FD9932 42 in. Plasma Television Logo
634 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
