Question about SuperVent 6-in Stainless Steel Ceiling Support Kit JSC6DCSP
We were given an 87" stainless steel propane patio heater. Our deck ceiling is 96". Will that be enough clearance?
Had a look at the manual on a BFX750 patio heater and the distance required is 50cm above (18") and 60cm to the side (24"). If its the same type with around 13kw or 44,000BTU/h of power then this is the clearance is needed for air and heat.
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
My GE monogram has white panels, and I want to change them to stainless steel. Where can I buy them, and do I need a special trim kit? Thank you!
The model number that you referenced appears to be a stainless steel model. I know of no trim kits available.
Some of the older models did have door trim kits available.
Model PSS26MSRSS should be a stainless steel model unless this is the wrong number.
You can call the GE answer center at 800-626-2000 and get the information you need.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Our ceiling fan do not move any air at all.
    hello sir/mam
    please confirm you have fixed the blades as per the manufacturer and then you can change the pitch.
    Sep 14, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    Ceiling fan wont move much air even on high speed
    shut off fan, wait until it comes to a complete stop. switch button on base to other position. turn on
    Sep 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    Do I have a stainless steel drum in my washing machine?
    If the drum is unpainted and a magnet is able to stick to it, the drum is steel. If there it is shiny and uncoated, more than likely it is stainless. Checxk web site documentation
    Mar 01, 2009 | Washing Machines
    Is there a touch up paint for stainless steel?
    there is no paint for the brushed steel outside but you can get a stainless conditioning kit from the manufacturers this helps hide some of the smaller scratches if it is a big/deep scratch there is nothing you can do with it unless its on one of the doors and the panels are available to purchase
    Feb 24, 2009 | Bosch Evolution 800 B20CS80SNS Stainless...
    Can I get a different front door for my dishwasher?
    From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
    SGZ1005UC Stainless w/tubular Towel Bar Handle
    SGZ1006UC Stanless w/curved Handle
    Feb 06, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
    Maytag ice maker flap keeps opening like it was possessed
    If the flap your mentioning is the one that opens and closes that is on the freezer door,than it needs to be replaced with the "Fountain Kit ".In this kit you will have the parts that control this problem.Replace ALL the parts that are in this kit with the parts off your old one.If installed correctly ,the problem is fixed.
    May 12, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
    SuperVent 6-in Stainless Steel Ceiling Support Kit JSC6DCSP Logo
    76 people viewed this question
    Top SuperVent Dryers Experts
    Are you a SuperVent Dryer Expert? Answer questions, earn points and help others
