Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Lacie 500gb quadra external drive won't boot using USB cables.
I have a Lacie 500gb quadra external drive. It will boot up using the firewire cable but will not boot anymore when using the USB cables. At first it would boot using a differnet USB port on my mac bur now will not boot on any USB port. This problem started after a power outage to the system. I believe it may have to do with the drive being improperly shut down. Is it a fragmentation problem or a driver problem?
  • scott653 May 19, 2009
    I have a Mac
  • 1,959 Answers
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
Posted on May 19, 2009
Lacie d2 Quatra 500 BG ext drive Windows XP won't mount. light blinks sounds like it's cycling inside. Any solutions? Need new driver?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 16, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
On a lacie external usb2.0 firewire 400/800 1TB, I'm getting a blinking blue led whenever the drive gets connected via usb. I dont have a firewire cable to test, but the drive was working fine on same...
Plug in power first. Connect usb cable. Turn on drive. Under my computer/computer locate the partition called lacie. Open, run the exe utility.
Aug 03, 2011 | Computers & Internet
LaCie 500GB portable hard drive is giving error 43. It was working fine for a few weeks and now I can't get into it from either of my computers. I tried uninstalling the USB Controllers but still same...
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If a different LaCie product is available, borrow the power cabling from that unit to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to a second port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test.
Then run
Dec 22, 2010 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
My lacie d2 quadra 500 gb hard drive does not mount in my computer when turned on
I can offer some simple advice based on windows PC's for these types of hard drives and that is contained here
http://www.fixya.com/support/r4247716-usb_device
It assumes USB type connection but I have also had firewire and e-sata issues with the cables supplied so tend to buy the ones that have the lock on them as these tend to be a little better
Bob
Oct 14, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Cord to use for installation
is there any option cables highlighted during the installation? check your cable what you are using right now..
Jan 16, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
494 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
