Question about Honeywell Heating & Cooling
Changing batteries I Honeywell thermopro 3
How do I change the battery
    Scholar:
  • 45 Answers
Any Honeywell thermostats I have come across you slightly tug on bottom of thermostat which disengages it from the wall and lift up. Batteries are then exposed. Replace with new and reverse take-off procedure to remount. If I remember correctly these do have a small battery backup to save your initial settings so you do not have to reset time and program. Can you tell me the complete model number of thermostat or send a picture of it?
Posted on Jan 01, 2014
I just finished changing the 3 AAA batteries and now the themostat does not work so... how do reset my honeywell digital thermostat? to get it to work again
Found this for you:
Insert the batteries backward, so that the negative pole lines up with the positive terminal. Leave the batteries placed backward for at least five seconds.
Remove the batteries and put them back in the correct way, then close the battery door. The display will turn on. The thermostat is now reset
May 17, 2017 | Honeywell Heating & Cooling
My honeywell st9400c changing from auto to continuous
How old are the batteries? You may want to replace them to see if it helps. If it doesn't then get a new thermostat. Nothing inside the AC/Heater will cause that.
Mar 24, 2014 | Honeywell Heating & Cooling
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    Dec 09, 2010 | Heating & Cooling
    What can I do to fix my Honeywell thermostat -- I didn't turn it off before changing batteries and now it won't work at all
    Hello
    If the thermostat will not turn on and it has good batteries as back up to wall DC voltage then the conclusion is that the Thermostat has failed, these are considered throw away and are not serviced by Honeywell except under warranty and then they send out a new one and "thrash" the old one, so fixing it is not an option, you will need to just replace it, a good quality electronic programmable T-stat is less than $40.00.
    Oct 29, 2010 | Honeywell Programmable Thermostat Heater
    Heating & Cooling Logo
    355 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
