Question about Vehicle Parts & Accessories
Engine dies while driving
While driving the vehicle stalls
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 61 Answers
Need new fuel filter .or fuel pump problem....try to change fuel filter first ..if no results fuel pump problem
Posted on Dec 30, 2013
How do i fix my 2001 buick lesabre the engine stalls when driving it?
Usually when a computer controlled vehicle stalls while driving it's related to the Crank Position Sensor.
Sep 21, 2014 | 2001 Buick LeSabre
My car is turning on but stalls I have a Volkswagen Jetta 06 2.5 engine. PLEASE HELP
Vehicle starts but stalls.These types of problems are very common on most of vehicles.There are few possibilities,that can cause stalling problem on vehicle.The vehicle brand and model may differ but problem is same.------I provide you few suggested help link to troubleshoot these issue and solve the problem:-----------
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold? http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
-------------1994 Toyota 4Runner: Stalls and Stops While Driving? http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
-----------1992 Chevrolet stalls and shutdown? http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
-----------Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot? http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
------------Engine stalls when gas is given? http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
------------1990 mazda 323 stalls and quit running? http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
------------Nissan Pathfinder stalls and bucks on Acceleration? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
------------Car stalls when MAF sensor is connected? http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
-----------Car Engine Stalls While Driving? http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
--------- Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
These are few help links,that will help you to troubleshoot the issue and solve the problem.Please keep updated,if any more help required.Thanks.
Oct 20, 2012 | Cars & Trucks
1999 Ford Explorer, sluggish or stalls in Drive
Check the speed sensor on the power steering and replace if it fails to increase engine speed when the wheel is turned.
Nov 28, 2017 | 1999 Ford Explorer
I have a F250 lariat with a 460 - truck stalls when I put it in gear - even after it runs for 20 min. Sometimes it will stall while I'm driving. I had carborator replaced last year. Hope you can help.
Some possible causes could be:
Vacuum leaks cause an engine to run lean witch can cause the vehicle to stall when put into gear.
Improper base idle adjustment can cause the vehicle to stall when shifted into drive or reverse
A malfunctioning or damaged carburetor can cause the vehicle to stall when shifted into drive or reverse
Improper ignition timing can cause the vehicle to stall when shifted into drive or reverse.
A malfunctioning or damaged transmission or torque converter can cause the vehicle to stall when shifted into drive or reverse
Oct 31, 2010 | 1987 Ford F 250
Vehicle stalled out while driving, will not kick over
There is no carb, either throttle body or fuel injection.If it was fuel related it would not cause all the lights to come on.Sounds like electrical and will have to be tracked down and diagnosed. Your computer may have gone out but that has to be diagnosed.
Aug 05, 2009 | 2002 Chevrolet Blazer
Randon stall, no start
If it is the 2.5 v6 , you most likely need the distributor replaced. If it is the 2.4l cam and crank sensors would be most likely cause.
Jul 13, 2009 | 1998 Chrysler Sebring
Rpm fluctates when warming up and also stalls when
Check the egr valve & for other vaccuum leaks.
Jul 13, 2009 | 1993 Nissan Pathfinder
Vehicle Stalls
is it setting any codes?
a stuck open EGR valve will cause this problem
Oct 25, 2008 | 2004 Lincoln Navigator
2005 g6 stalling
I would suggest checking your wiring (core wire on the distributor, plug wires and the negative battery ground) I would imagine that the forward motion of the vehicle is possibly making your wires lose connectivity and making the car stall. Just a thought though.
Carl
Sep 12, 2008 | 2005 Pontiac G6
Vehicle Parts & Accessories Logo
80 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
