Question about Dell Precision Computers & Internet
I have a T3500 Xeon Q core with 2.66MHz with some softwares the processor cres speed go up to 78 degrees Celcius and the fans run slow. Any solution to raise the fan speed
  • 28 Answers
You need to access the motherboard's BIOS. This is usually done by pressing either Del or F2 on your keyboard when you hear the beep sound as it boots up. Be careful though because the wrong settings could cause your computer to malfunction. Or you could also google search for a solution. There might be a software that allows you to do that.
Posted on Dec 30, 2013
SOURCE: uncontrolled CPU fan speed
have changed CPU fan once but it is not proper so I changed the same one earlier used but from that time the CPU fan speed is uncontrolled the speed is not vareying as per the processor load. I will go to the setup and adjust speed to a different value but no change is ocuured in the fan speed.I think some problem occured in mother board. Pls find a solution for this problem. Thankyou .I have checked the bios and change the fan speed but no change is come on the fan speed and the connections of the fan are correct please find a solution. the fault is maybe in the motherboard
Posted on Oct 03, 2007
rtrahan
  • 741 Answers
SOURCE: bios update can resolve lack of fan's control?
Probably not as you can only flash your BIOS from the manufacturer, so that is probably the latest version they produce since you got it recently. Under no conditions do I recommend trying to flash BIOS from someone other than the orignal manufacturer as any mistake will cause your computer to become unbootable.
Posted on Dec 26, 2008
SOURCE: CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Posted on Feb 10, 2009
Killer Ape
  • 10 Answers
SOURCE: fan won't cool enough, causes random shutdown
Try Speed fan
Posted on Aug 14, 2009
  • 8 Answers
SOURCE: i have Dell GX280 system. My Fan produces more
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Posted on Sep 09, 2009
Code error: 3700:011b Mgs: Front fan -the Fan speed is incorrect
it could indicate bad bearings, which means the fan needs to be replaced. It's easy and not terribly expensive. Take the fan out, google the numbers on that fan to get an exact replacement, and install the new fan. the 3500 is a heavy beast, but its not terribly tough to tame.
Nov 23, 2014 | Dell Precision T3500 Computer Workstation...
Why won't t3500 power on?
Most likely cause is the power supply, if it really wont turn on, if it comes on but doesnt start, the you have a computer problem. Check and see if the fans work when you push the power button or if any lites come on, then the power supply is most likely OK. If the computor does actually come on, but does not start, see how may beeps it makes. then repost your question with that info.
May 05, 2014 | Dell Precision Workstation 490 - MT -...
I have XEON Core Duo processors with Dynatron heatsink fans attached. One of my CPUs is running about 8-10 degrees hotter than the other one and if I let it idle they both heat up until the alarm sounds...
Hello try to download the manual here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dae.cfm
The fault could be a wrong setting in the bios chipset or cpu option.
Maybe one of the cpu has a wrong mhz setting ( overclocking )
This will make the system unstable.
75 degrees celcius is too hot even for a intel cpu.
Try to reset the bios to factory settings.
And look also for an bios upgrade.
WARNING!
Please do not download / upgrade the BIOS/Firmware UNLESS your system has a BIOS/firmware-related issue. Flashing the wrong BIOS/firmware can cause irreparable damage to the system.
Remember to add new cooling paste, not much, when removing the cooling element and fan.
Good luck
Jul 31, 2013 | SuperMicro X7DAE Motherboard
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
I have 2 problems: 1. can this type acer run mac os? 2. the machine came with duo core processor but i upgraded the machine by removing duo core and put core 2 duo 3.0 processor, now the machine is...
The answer to your first question is yes, your computer is compatible with the MAC OS. However it is very important to continue to ask this question to the MAC Salesperson you deal with when purchasing the software.
The answer to your second question is to do with Heat. Your computer is overheating and is therefore slowing down so it does not fry your CPU. You need to ensure that the Processor Heat sink is making proper contact with the CPU and the fan is connected to the computer main board. Clean the computer of all dust and install as many fans as your computer chassis will allow.
I think this chassis supports up to 80mm fans.
A well cooled computer chassis will work efficiently and effectively.
The Cooler Master Geminii S CPU cooler is a very good CPU cooler for your Processor.
It will reduce the temperature of your Processor by several degrees.
It is very important to get as much, cooler fresh air into your computer chassis as possible. As this will mean that your computer system will run at a far cooler temperature.
damnor01
Feb 08, 2011 | Acer Veriton M265 (PSV880Z001) PC Desktop
Overheating as soon as i am in slow traffic she wants to run at 100 celcius
How many miles are on the vehicle??? Is the coolant level full???
Jan 22, 2010 | 1995 Jeep Grand Cherokee
I have a Question for upgrading my machine. I havent had the chance to dabble with Dual-Processors.... This will be my first time. Q: Is it possible to utilize a Xeon 2.66GHz x3330 Processor and a Pentium...
You can only mix the same family processors with different stepping and speed. Pentium D is not in the same family as a Xeon. So no, you can not. For as long as the processors are in the same family, you can mix dual core with quad core and even different speed.
Sep 02, 2009 | Intel Quad Core Xeon X3330, 2.66 GHz
Computer runs too hot then shuts down
remove your fan and install new one ,your hit sneak is not working properly ................ok
Apr 03, 2009 | Acer Aspire One PC Notebook
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
