Question about HP PSC 950 All-In-One InkJet Printer
Printer won't accept my paper
I'm using 8 1/2" x 11" paper, and the printer stops the operation and gives me a message that the paper is too narrow.  I have not been able to get it to print.
  • peterdalby Feb 29, 2008
    same problem please advise
  • Anonymous Mar 25, 2008
    have the same issue; turned off; tried setup key, then 5 and 3 - this happened following a paper jam but don't see what bearing that might have
    Novelist:
  • 188 Answers
Hi
Pleae click on the web link given below and perform the steps provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05026&cc=us&lc=en&dlc=en&product=60259
Have a great day!
Posted on Apr 02, 2008
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
I continue to receive "paper too narrow. load with wider paper" message despite using 8 1/2 x 11" paper. This was not an issue I've ever had before and am using the same size (standard) paper as I always...
Check the Paper Size Settings.
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
If you have a problem just reply on us.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
Hp 6110xi error message 'paper too narrow' caught in infinite loo
please check out the following Hp website link.... it gives a resolution for ur problem with pictures....
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpu00804
thank you good luck
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Overheat message comes on.
First, you need to make sure that you are using the best settings for your printer. Here are a few things to consider:
1) Environment - If this printer is stored in a cabinet, under a desk, on the floor, etc., it is likely that any heat created by the fuser doesn't have room to escape properly. Be sure to give at least an 1.5" clearance on all sides.
2) Power - The parts inside of a printer are all rated to operate using certain voltages. That being the case, you need to use unregulated power (i.e. - wall outlet) to make sure the parts are given as much (and only as much) power as necessary to operate. Using powerstrips rated at different voltages can create either not enough or too much power which could mean the fuser operates at too low or too high of temperatures.
3) Media - Make sure the paper you're using is rated properly for the printer. Most printers accept a certain paper weight (found in the owners manual). Contact Dell if you've misplaced this.
4) This particular printer isn't rated for too high a speed, which means the fuser shouldn't have to run as hot. If you still get overheat messages, you could try updating the firmware on the printer at support.dell.com or even contact their technical support.
May 29, 2009 | Dell 1600n All-In-One Laser Printer
Printer shoots out blank paper
Hello. More than likely, there is an issue with the paper feeder itself. My HP printer did the same thing, and HP took care of the problem for me. If you call the manufacturer, you should be able to send it to them and they can fix that issue. If you have any questions, please contact me at loganhrrs@yahoo.com
Mar 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper feed problem
usb port or printer adapter problem.check both of them.wish success
Jun 04, 2008 | HP Deskjet 2360 InkJet Printer
Printer won't accept paper
What jam code are you getting. I suspect a registration clutch issue. But there should be a code associated with the jam.
I would like to look that up and narrow it down for you.
Mar 13, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Hp psc 2210 all-in-one
My computer will not allign right. It says paper is too narrow...insert wider paper...then refuses to do task . All the paper is the same. It is not the paper. What do I do?
Jan 09, 2008 | HP Printer/Scanner/Copier 2210 Ink-jet...
HP PSC 950 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
