Question about Intermec CK71 Handheld Mobile Computer CK71AA2MN00W1100 Barcode Scanner
Ck71 not sending tab after scan
Can you use datawedge on ck71?
After i scan with mc70 i have to press enter
Try configuring ScanWedge/DataWedge (it should be running).
  • Open the app
  • Click on the icon and on the menu select Config > Setup
  • Select 'Send ENTER key after suffix'
  • Click the 'OK' button
That should be it..
Jay
bb87eb9b-28f2-4b6a-a057-6937ebfe690b.gif 095d25dd-2241-46a9-a130-39a63c08239e.jpg
Jan 21, 2014 | Symbol MC70
CK71 stuck on Launching OS
Hi
Please try to Install OS through Intermec Smart System from intermec.com - downloads
and try to install OS via WIFI connection
Note : Make sure about WIFI Connection & Battery Charging power of device
Regards
Aug 22, 2011 | Intermec CK71 Handheld Mobile Computer...
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Aug 04, 2011 | Zebra Symbol Technologies MC909X-G Series...
Hello, I am with Motorola and have a MC5590. The scanner function does not appear to be working. I have version 6.5. Do you have an instruction set that can test the functionality of the scanner? Thank...
Hello Glenn,
to test the scanner I would suggest to download and install the Datawedge application. It is an desktop installation. As you will connect your MC55 to the Desktop per Active Sync the application will be installed also to your MC55.
The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, if you scan a barcode a pop-up window will come up. Or if another application is running it will send the input to the application.
Nov 08, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Scan bar code using motorola MC75
Jul 15, 2010 | Zebra Symbol MC75 Portable Data Collector...
How do you turn on the BCR scanning
if you are looking to turn on your barcode scanner, i would recommend you download datawedge. It is the most common scanning application that Motorola recommends. If you have an issue finding this you can contact us at www.datexcorp.com and we can send you link
Mar 17, 2010 | Symbol MC9090 Barcode Scanner
Im using DataWedge v1.0 for scanning the barcode in Motorola MC55.How can i get scanned data from DataWedge to my application.i.e where DataWedge will store the scanned information.Thanks.
You need to be in an application first. For example, launch mobile Excel and make sure your cursor is in a cell. When you scan, it will enter into that cell. Just make sure the cursor is in the cell you are trying to get the info into before you scan (If it's not working, the app you're running may not be compatible with the scanning function, but I've never seen this).
Oddly enough, from what I've seen, if you just scan something without having an app launch, I've seen the MC70 default to the phone function and try to dial the number scanned.
Feb 18, 2009 | Symbol MC70
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Intermec CK71 Handheld Mobile Computer CK71AA2MN00W1100 Barcode Scanner Logo
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
