Question about Karcher Garden
How to fix ez surface cleaner - Karcher Garden
How to fix dirty copy in np7250
You better upload an image, because there are many kinds of "dirty copy". Also you'll need to check the counters to see if is not the time to replace Developer Unit or Fixing Unit. Check the surface of the Pressure Roller and Heater Roller in the Fixing Unit., also check the surface of Developer Roller if the are scratches or other kind of damage on them. In some cases you need only to clean the printer inside with vacuum cleaner. Be careful not to produce any damage to the printer components. Do not touch Drum surface or Developer roller.
Jan 26, 2015 | Office Equipment & Supplies
What is the best product to remove ring in hot tub?
SECRET:
Use a a Good Quality Name Brand "Filter Cleaner".
Works great as a surface cleaner for your hot tub.
May 26, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Surface cleaner won't spin
I agree, the teflon rings appear to br the only things that wear (aside from the hole size which could wear from water abrasion, but unlikely). That would explain the metal to metal sound you hear at times because the seals prevent wobbling.
Nov 30, 2012 | Garden
Can I use vinegar in a hot tub as a descaler
I would advise against vinegar. It is a weak acid which may have an adverse affect on your plumbing, spa & jet surfaces even if you intend on draining the spa for cleaning.
I doubt it will be able to cut the mineral build-up anyway.
Here are two ideas Scale preventer or Jet Cleaner which work well on acrylic spa's. Just check with Roto-Dreamaker first to see if they will be okay on their plastic.
If you want to try something else before buying those try using a mild non-abrasive, non-sudsing cleaner with a soft cloth or nylon type scrubber to the build-up. Also try baking soda either option should be okay for the plastic.
The cause of the build up is not usually owner related but the water chemical composition in your area. Your local pool/spa store will have the best advice for your local water chemistry.
Jan 08, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
How to install belt on eureka ez kleen vacuum
While this answer is not for your specific model vac, most belt changes are very similar and pretty straight forward. Have a look at this video to see how it's done.
Oct 19, 2011 | Eureka EZ Kleen Cordless Lightweight Stick...
I was removing my drivers side fender and 3 of the bolts came out the it came of clean and it is flushed in the surface ut the studis still in the hole what can i do to fix it
An EZ-OUT assortment is available at hardware or auto parts stores (as in Pep Boys).
A hole is drilled in the center of the broken bolt -- size of drill bit depends on size of bolt -- drill bit size is marked on EZ OUT.
After drilling hole, the EZ OUT is screwed in counter-clockwise, it tightens inside the drilled hole and the broken bolt comes out as the EZ OUT is turned. It's best to use a wrench on the square end of the EZ OUT to turn it.
Charlie
Jan 09, 2011 | 1995 Nissan Maxima
EZ Dupe CD/DVD Duplicator keeps giving the error message, 'Source Not ready" No matter how many different CDs I put in the top disc slot, it keeps detecting an error
Have you tried cleaning the lens?
3M makes a CD lens cleaner that is a playable CD with micro brushes sticking out of the surface of the CD.
You can find them at office supply stores, K-mart, etc. I don't remember where I bought mine, but it works great for a CD-recorder that I use in a high dust environment.
Here's a link to one that I just found by googling "3m cd lens cleaner"
I've never dealt with that vendor before, but it has a picture of the product so you can see what I'm talking about.
Feb 12, 2010 | Computers & Internet
I used the wrong cleaner on my Pegaus black vanity top. Now it has spots on it. Is there any way to fix this?
You may have etched the surface with the cleaner, but let's hope not.
Go to your local auto parts store and get a can of Polishing Compound - NOT rubbing compound...this product is used to remove surface blemishes from paint and other smooth surfaces. Try it on a small area only. If it works, you can use it remove the other spots. You can then use an automotive car wax to protect the vanity top....I like Nu-Finish...great product.
Dec 06, 2009 | Pegasus Technologies Pegasus Black Glass...
Air-o-swiss 7142 humidifier
I just cleaned mine for the first time, and the instructions are very unclear in the pamphlet on how to do it.
What you need:
One package of EZ Cal cleaner/descaler for humidifiers ( I got mine at bed bath and beyond)
32 oz of hot water
How to clean your unit:
Mix the hot water with the EZ Cal cleaner packet in a separate container.
Remove the tank from the base.
Remove the cleaning brush and the silver stick that is in the base of the unit.
Pour the solution in the base of the unit.
Let the solution sit in the base of the unit for 1/2 hour.
Then take the cleaning brush, and go over the surfaces in the base.
Pour out the solution, and rinse with hot water.
Put the brush and silver stick back into the base.
Put tank back onto the base.
Reset the unit by pushing and holding the power button for a few seconds.
This will stop the cleaning indicator from blinking.
Let the water fill up the filter for a couple minutes, turn on, and your ready to go again.
I hope this was helpful.
Nov 03, 2008 | Air-O-Swiss U7142 Humidifier
Garden Logo
115 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
