Question about Garden
Bilt that runs off of main drive pulley keep, to deck comes off
This bilt runs off of the main drive pulley it ingages the deck when the control arm is moved forward. the bilt frays and come off often is the pulley ajustment off or what please help these bilt are not cheap, thank you. it's a troy-bilt Horse V-twin 21hp 46 inch cut.
    Sniper:
  • 57 Answers
If you have an owners manual, verify correct routing of the belt. If this is correct, check all the pulleys with the belt off to ensure they turn freely. Recommend not mowing with the deck in a very low position also. This creates an awkward alingment. Let me know.
Posted on May 19, 2009
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
How do i replace drive belt on husqvarna zero turn model#96645580
To replace EZT belt
Park the mower on a level surface. Engage the park brake.
EZT belt removal
NOTE: Be careful not to damage the fan blades on the EZT as this can affect cooling or damage the EZT.
  1. Remove the deck belt
  2. Create slack in the belt by pushing the spring loaded idler arm away from the belt.
  3. Rotate arm to release belt tension.
  4. The belt should now be able to be removed from the engine pulley and EZT pulleys.
Belt installation
  1. Wrap the EZT belt around the EZT pulleys.
  2. Wrap the belt around the engine pulley.
  3. Route the belt around the inside of the idler pulley while keeping tension off the belt and then slowly the idler assembly afterwards.
  4. Check that the belt is on all the pulleys correctly and test drive your unit.
  5. Afterward then re-install your mower deck once your are satisfied with the drive installation..
Feb 18, 2015 | Husqvarna Garden
How to change the transmission drive belt on a Troy-Bilt riding mower
IF YOUR MOWER COMES EITHER TRANSMISION AMD DRIVE BELT OR ONE EXTENDED BELT, YOU HAVE TO LOSE THE CUTTING DECK AND DISMOUNT THE OLD BELT, TO REPLACE THE NEW ONE FOLLOW THE DRAWING NORMALLY PRINTED ONYSTHE DECK ADJUST TENSION WHEN YOU MOUNT BACK THE CUTTING DECKALOWING THE BELT TO BE LOOSE A LITTLE, BY PUSHING THE ONE PART OF THE BELT IN BETWEEN PULLEYS FOR A ONE INCH OF PLAY AND YOU ARE SET.
Jul 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt lawn mower
check to see if spindle bearings or bad or a bent or split pulley or bent or twisted deck or for broken lawn mower frame uallaslly around a weld frame twist deck belt comes off
Jul 10, 2013 | Garden
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
1046 cub done 120hrs 12mths old replaced all pullies bearing use 5 belts in 12mths belts keep comeing off is this a problem with this modle 2009
hi,
on some cubs there are two holes for the spring loaded pulley adjustment arm. take the deck back off and look at the spring loaded pulley arm mechanism, if theres two holes , take the bolt out that holds the adjustment arm down and move it to the other hole. theres two holes for the spring too, try the other hole, make sure your spring isnt upside down. putting the spring back on is difficult. connect it to the front first then come around the back with a spare piece of rope, put it on the spring and pull on the rope to get the spring back on the mower deck. use eye protection and be careful.
jm
Apr 23, 2011 | Cub Cadet LTX1040 Deck Belt 2009 Only...
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
Nov 07, 2009 | Garden
The drive pulley above the PTO won't come off the crankshaft
Hello bob2kat:
>>Have you Removed the Allen Lock from the Pulley?
>>Did you Clean the Crankshaft with Sandpaper before trying to Slide the Pulley Off the Shaft?
>>Thanks.
Respectfully
John
Apr 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
280 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
