Question about Honda 30300-943-004 Authentic Generator, Pulse 81-83 Atc110
30300-943-004 I am fixing my 3 wheeler and cannot find the Generator pulse.. anyone know were I could get one new or used in good condition? thanks
3 Suggested Answers
gisvc
  • 40 Answers
SOURCE: 1985 honda shadow vt500c pulse generator
hi,
locate the crankase cover to the left of the engine towards the lower end of the motor. if the bike has a center stand place it upon it t\and undo the crank cover once removed you will visually see the pulse generator it is like a large type style magnet. good luck
live free ride hard..
Posted on Mar 30, 2009
Thermo King
  • 593 Answers
SOURCE: I need a pulse generator!!!
http://www.drumhillcycle.com/
http://cyclesrus.net/
Try these sites for your used part needs. Did that sound like a commercial, man I am doing this too much.
Posted on Feb 05, 2010
Indian three wheeler wiring diagram
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.bajaj Indian three wheeler wiring diagram Google Search
imarksweb net
BAJAJ 4 STROKE 3 WHEELER SERVICE MANUAL
Ape Piaggio Three wheeler parts Bajaj three wheeler spares Bajaj Pulsar... Inside view of three wheeler engine
Sep 28, 2013 | Bajaj Motorcycles
Where is the cam sensor at
Description & Operation
2.5L Engines
On the 2.5L 4cylinder engine the Camshaft Position (CMP) sensor is located in the distributor.
The sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the distributor shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the Crankshaft Position (CKP) sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the leading edge of the pulse ring (shutter) enters the sync signal generator, the following occurs: The interruption of magnetic field causes the voltage to switch high resulting in a sync signal of approximately 5 volts. When the trailing edge of the pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts. 4.0L
The Camshaft Position Sensor (CMP) on the 4.0L 6cylinder engine is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of the engine near the oil filter.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the oil pump drive shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the trailing edge of th4.7L
The Camshaft Position Sensor (CMP) on the 4.7L V8 engine is bolted to the front/top of the right cylinder head.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects notches located on a tone wheel. The tone wheel is located at the front of the camshaft for the right cylinder head. As the tone wheel rotates, the notches pass through the sync signal generator. The pattern of the notches (viewed counter-clockwise from front of engine) is: 1 notch, 2 notches, 3 notches, 3 notches, 2 notches 1 notch, 3 notches and 1 notch. The signal from 5.7L V8 Engines
The Camshaft Position Sensor (CMP) on the 5.7L V-8 engine is located below the generator on the timing chain / case cover on the right/front side of engine.
Fig.
The CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders. The sensor generates electrical pulses. These pulses (signals) are sent to the Powertrain Control Module (PCM). The PCM will then determine crankshaft position from both the camshaft position sensor and crankshaft position sensor.
The tone wheel is located at the front of the camshaft (2). As the tone wheel rotates, notches (3) pass through the sync signal generator.
When the cam gear is rotating, the sensor will detect the notches. Input voltage from the sensor to the PCM will then switch from a low (approximately 0.3 volts) to a high (approximately 5 volts). When the sensor detects a notch has passed, the input voltage switches back low to approximately 0.3 voltsthe CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinderse pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts
Jun 08, 2012 | 1999 Jeep Grand Cherokee
I have cleaned everything in the carbs put new jets in it and it still is doin the sputtering
first do the easiest go to Autozone and purchase a can of Sea Foam pour in 1/3 can to two gallons of fresh fuel... if you can clean out or replace fuel filter. Now start it up ...if it wont start then push start it and get on it an go;drive it on an open highway for about 10 to 15 miles and see if it clears up the problem. it took me 11 miles of sputting then all of the sudden in the middle of a turn all my horse power came back. Now if that didn't fix it, take one of your spark plugs out and let it hang and touch the frame crank it over an see if its getting a "big fat bluish spark" if it looks "purplish-red" thats no good, and you need to ohm out the pulse generator system. follow wire harness from pulse generator to nearest disconnect and ohm out the wires, should be four wires measure two at a time you should get approx 400 to 500 ohms, when i had a problem i was reading 136ohms on one set and an open on the other..i took off the cover and looked at it and you could see that one of the was burnt..so i replaced it and it started up good and ran like new.
hope this helps out or at least guides you closer to a fix..let me know if it helped thanks!
Apr 30, 2010 | 2001 kawasaki ZX-6R Ninja
No spark
check pulse generators first, i found one burnt and one was open on my 87 hurricane 600. Ohm the wires out for opens or low ohm readings readings,they should be about 400ohms or more. if thats good then check out spark unit..if thats good then check to see if coils wires are getting 12v. Then if that is good check resistance of primary and secondary plug wires. or just replace them anyway and that one less thing to worry about. you have new plugs and wires. it can only really be the coils or pulse generator. hope this get you in the ballpark can iget a helpful on this thanks but if i helped you fix it by checking the pulse generators i'd like a very helpful, appreciate!
Apr 10, 2010 | 1987 Honda CBR 1000 F
My honda's CDI is not working .i replaced that with a new but not good. i want to ask that can i fix CDI from another modal to my bike?
How do you know for sure its not working ..it could be a pulse generator causing the problem.
Aug 29, 2009 | 1993 Honda Jade
Hi,I've a 98 Fireblade and can't get a spark
Hi and welcome to FixYa,
To my understanding, there are only 2 wires from the ignition pulse generator:
  • yellow - pulsating 0.5 VAC when cranking; and
  • white/yellow - ground.
A couple more of initial checks:
  • IGN +12 on the black/white wires of the ignition coils;
  • IGN +12  on the 3 wires of the engine stop relay other than the red/orange;
  • 0 volts on the red/orange (red/white) wire from the BAS (bank angle sensor).
Good luck and thank you for asking FixYA.
Aug 20, 2009 | 2001 Honda CBR 929 RR Fireblade
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
1998 honda vtr firestorm starting problem
Hi Samantha!
Yepp, i know whats wrong. Its the generator on your bike that dosent work properly. The generator dosen charge your battery. So when your drive the engine, the lights, the flash etc take all the power of the battyre and since the genarator coulden charge it properly it dies.
Buy a new, or if you can find a used, generator and replace it, alternative take the generator to someone that can pull it appart and replace the coals in it. Sometimes thats more expensive to change the coals then it is to buy a used one.
Good luck with your bike
Nic
Jun 03, 2009 | 1997 Honda VTR 1000 F Firestorm
hi,
Mar 15, 2009 | 1985 Honda VT 500 C Shadow
Yamaha timberwolf 4x4 carberator issues
Firstly, if you are not a mechanical person you should never buy a vehicle that does not run.
However, here are some basic tests.
1. Connect a good battery.
2. Remove the spark plug.
3. Turn the motor using the starter motor or kick starter.
4. check for spark by inserting a new plug into the plug cap. (make sure the plug is grounded).
If the motor turns freely and there is spark, chances are good that the motor will run. This does not mean that the motor is in a good condition. Only with the motor running will you be able to know for sure.
You will now have to source a carb and fit it to the 4 wheeler.
Fitting the carb is not too difficult. Check that the intake manifold is not perished or torn, and remember to use the airfilter.
Enjoy the ride !
Jon
Mar 01, 2009 | 2003 Yamaha YZ 250
Honda 30300-943-004 Authentic Generator, Pulse 81-83 Atc110 Logo
19 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
