Question about Canon PowerShot A2400 IS 16 Megapixel Digital Camera - Pink
Lense of canon digicam is not opening and shutdown.
There are lines in every pic i take T.T it's canon digicam
re
The lines may be on the screen, try looking at the pics on your computer or print one, see if the lines are still there
Feb 16, 2012 | Casio Exilim Cameras
SHOWS LENSE ERROR, RESTART THE CAMERA, AND SHUTDOWN AUTOMATICALLY CANON A 1000 IS POWERSHOT MODEL
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Canon Powershot A1000IS Digital Camera
DSC-W12: the batteries last only a few minutes before they're drained. Camera draining batteries very quickly.
If its a Lithium ion battery(similar to a mobile phone battery) then open battery compartment, clean battery contact points and try again after recharging the battery. If the camera uses AA batteries look for the current ratings on the side of the battery, generally digicams need batteries with more than 1200 mAh (I use a 2000 mAh for my Canon SX110 IS digicam). This current rating may vary for different manufacturers.
Jul 25, 2009 | Sony Cyber-Shot DSC-W12 Digital Camera
Canon digital ixus 860 is - user manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=9825
search around on this website it is able to be downloaded there in many forms.
Jun 23, 2009 | Canon IXUS 860 IS Digital Camera
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
Digicam as webcam
how to connect the cannon a1000is to use this as webcam? plz plz plz plzplz solve my problem
my name is mohsin ? or email address tarzanmohsin@hotmail.com
Jan 28, 2009 | Canon Powershot A1000IS 10MP Digital...
Canon ip90 prints everything reddish
First, check out the stickies. Also, read this article at Steve's Digicams.
http://www.steves-digicams.com/techc...June_2005.html
Also, make sure your monitor is calibrated. Even using software calibration such as Adobe Gamma will help.
Jan 14, 2009 | Canon PIXMA iP90 InkJet Printer
"Cover opened" error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 14, 2007 | Kyocera Finecam L4V Digital Camera
Canon Digicam IXUS800 - Drivers
go to the link below for the drivers http://software.canon-europe.com/products/0010329.asp
Sep 06, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
What is the problem of my Digicam when i Turned it ON the LCD screen has blured display and I can only see lines and pink color of the display.. can anyone help me fix the digicam.. I appreciate all ur...
This is a defective CCD and is being replaced free of charge by Canon. Go here to get details on returning to Canon for a free repair: http://www.imaging-resource.com/badccds.html
Nov 18, 2006 | Canon PowerShot A75 Digital Camera
Canon PowerShot A2400 IS 16 Megapixel Digital Camera - Pink Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
