Question about Rosen A7 Car DVD Player
I need to replace the electric ribbon to the screen,where can i buy one?
I have a lt2030u gateway netbook I need a ribbon cable that goes from the screen into the keyboard. my screen is ok but when i close or open the screen flickers if I put pressure on the left side joint...
Jason,
AMAZON
no hits.
A eBay check for:
lt2030u gateway display ribbon cable
(and)
lt2030u gateway LCD ribbon cable
NO HITS!
Then I tried hunting for:GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREENS and found this part number for the SCREEN: Gateway F846431 hoping to track down a supplier? NO HITS there either!
My final recommendation? Go to eBay and look for Auctions:
352215358996
122852779509
Now go to the bottom and "Ask buyers and sellers about this product"... MESSAGE the guy OR ~ CALL him at:
(201) 830-1637
between 11:00 Am - 6:00 Pm ET
Monday through Friday (excl holidays)
MAYBE they have your cable?
Anthony
GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREEN 10 1 WSVGA...
Dec 11, 2017 | Gateway LT2030u Netbook
White screen - how do I fix that
Hi i must answer at least 10 of these a day with the white screen problem,
first of all this is a very common problem with all flip and slide phones and even laptops and netbooks.
now the problem is to do with the data ribbon that connects the screen to the circuit board this data ribbon is a thin ribbon that has several single strand copper wires running through it now when you open and close your phone this ribbon bends so as it keeps the connection with the screen.
over time these copper wires become brittle and break and this is what giving you the white screen
the only way to solve the problem is to get this ribbon replaced now as its such a common fault then this makes the part cheap to buy and cheap to get fitted, how ever its not something you can do yourself as you need special tools to remove and refit the ribbon.
your best and cheapest option is to take your phone to a small phone shop and ask them to replace this screen ribbon for you its such a common fault and that makes it a cheap part to get replaced.
so if you want to keep using the phone then it means your going to need to get this part replaced once you have got this part replaced you will have no problems using your phone.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 29, 2010 | Motorola Mobility RAZR V3
I'm trying to replace a Nintendo DS Lite ribbon cable to the top screen. I've heard that you have to replace the entire top screen. Is it possible that you can buy another ribbon cable instead of another...
Naa got to get a top screen they come with the ribbon cable no way around it they are cheap have a look on ebay u can get them for abt $10 delivered
Mar 21, 2010 | Nintendo DS Lite Console
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
NO DISPLAY
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Nov 07, 2009 | Nokia N70 Cellular Phone
Faulty game console
Maybe the ribbon cable was damaged. the ribbon cable is a flat wire thing used to connect the top screen and bottom screen. you can buy a ribbon cable on ebay for a cheap price.
if that wasn't the problem, maybe the bottom lcd screen is dead. you'll need to replace that.
Dec 26, 2008 | Nintendo DS Lite Console
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is: www.consoleparts4u.co.uk
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Mowcius
Jun 16, 2008 | Nintendo DS Console
Blank screen
there is problem with ribbon of ur phone, ribbon is that parts which connects ur slider part of phone to the lower part of ur phone. ribbon might be damaged. take it technician for replacing it with new one, once it will get replaced u will be able to see ur screen working.
Jan 13, 2008 | Samsung T809 Cellular Phone
Top Screen Replacement of DS Lite
there is a video tutorial at http://www.maxconsole.net/?mode=news&newsid=11484
which tells you how to disassemble the ds lite
Dec 04, 2007 | Nintendo DS Lite Console
Nintendo ds damaged ribbon cable
You can't buy a ribbon for the bottom screen. (You can buy the ribbon that connects the motherboard to the daughter board which connects the top screen.). A new screen is the answer but be very careful when taking off the touch screen. Gently pry the two screens apart or else you will need a new touch screen. Also make a note of how the touch screen is attached to the LCD screen, as the touch screen is not the same size as the LCD screen. How have you damaged the ribbon? Could it be that it may not be pushed tight and straight into the connector? BTW the top and bottom LCD screens are the same. Some unscrupulous dealers have been charging differing amounts for 'Top' or 'Bottom' screens!
Oct 27, 2007 | Nintendo DS Console
Rosen A7 Car DVD Player Logo
23 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
