Question about Lexmark Optra T612 Laser Printer
900 Service RIP software - Lexmark Optra T612 Laser Printer
  • 3 Answers
Service manual indicates this is a logic board issue, but I've seen this error numerous times, and a logic board never fixes it.
What ends up being the issue is a bad print job, could be caused by a bad driver. Test by disconnecting the printer from network, and printing the menu settings from the panel. If it prints, then it's a bad print job or driver.
Posted on May 19, 2009
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
don_farr
  • 1011 Answers
SOURCE: Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
Posted on May 21, 2009
SOURCE: 910 service engine + 900 service RIP software
931 service
Posted on Jul 09, 2009
  • 4 Answers
SOURCE: 900 Service RIP Software
Are there any memory or Barcode SIMM's in the printer? If so, remove them (power off first!) and turn the printer back on and see if it acts normally. I have had 1 instance where the Barcode SIMM has caused that error. The Barcode SIMM had to be replaced. Most other times the 900 RIP error occured, a simple turn off/on "fixed" it (sometimes only temporarily). If all that doesn't help, flash the engine code with the latest from Lexmark support. If that doesn't do it, then engine and/or controller card need replacing.
Posted on Jul 15, 2009
Mrinny
  • 94 Answers
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Posted on Aug 02, 2010
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
Problems with the c760 900 service rip software error, can you help?
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: http://bit.ly/c2xr1t. There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
Sep 02, 2010 | Lexmark C760 Laser Printer
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
Lexmark T520 I get an error code 900 service RIP software. further 44 p4 notify 001c-0300 page4/bios/fountain/notify.c-223:Inv eot:0 what does that mean, do I need a new engine board, or can I clear this...
Typically the engine controller circuit cards go bad. the firmware (software) get corrupted. you can try upgrading the firmware but ordinarly you cant clear the 900 service fault to try that. So your only solution is the replace the engine circuit card.
Dec 22, 2009 | Lexmark Office Equipment & Supplies
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Don
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
Jul 07, 2009 | Lexmark T520 Laser Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
May 04, 2009 | Dell Office Equipment & Supplies
Lexmark x422
Don
Mar 08, 2009 | Lexmark X422 All-In-One Laser Printer
Lexmark Optra T612 Laser Printer Logo
625 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
