Question about CorningWare SC60 Slow Cooker
Can't change temperature-stays on "warm"
When I plug the Corningware SC-60 slow cooker in, the digital readout shows "0". When I push the "on" button, the "warm" light comes on. I cannot change the setting to "high" or "low". Also cannot set "cook time." Any info out there?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
Posted on Dec 28, 2009
  • charles Dec 28, 2009
    Also, the manual says that after the full cooking cycle is completed, your Corningware slow cooker will automatically switch to the warm setting to keep food at a warm serving temperature.
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I'm looking for the manual for the Corningware SC-60 slow cooker. I need to know how to set the time and temperature. Thanks!
Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
Jul 27, 2010 | CorningWare SC60 Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
I need a lid for a sc-60 slow cooker. It broke
Corningware stated they are discontinued item. Unless someone is selling them on ebay they are hard to find. pyrexware is the maker maybe they have them or a means of getting them
Jul 06, 2009 | CorningWare SC60 Slow Cooker
NEED A REPLACEMENT GLASS LID FOR CORNINGWARE SC-60 SLOW COOKERW
I have this item if you want, I can send it to you. My slow cooker no longer works.
May 27, 2009 | CorningWare SC60 Slow Cooker
This is ridiculous. I just want the manual for the corningware sc 60 slow cooker so I can print it out. Why all the runaround. This should be simple
1. Turn off and unplug the slow cooker first.
2. Plug it in, but (yes, I know this sounds crazy) DO NOT turn it on.
3. Set your cook time and it will automatically set the temperature based on the cook time.
he The magic number is 7. Anything set for less than 7 hours will be cooked on high. Selecting a time more than 7 hours will result in cooking on low. Once the cook time has expired the cooker will automatically switch itself to warm until you turn it off. Follow these steps and you should be able to enjoy your cooker again! I don't know who was in charge of this type of setup for programming but they should be demoted at least - no wonder there are so many questions online about this one. Sure hope this helps you!
D
D
Nov 29, 2008 | CorningWare SC60 Slow Cooker
CorningWare SC60 Slow Cooker Logo
409 people viewed this question
Top CorningWare Crock Pots & Slow Cookers Experts
charles
Gerry Harvey
Gerry Harvey
raysaw
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
