Hard reset for LG 47LW5600
Need to do a hard reset. TV stays frozen on Life's Good boot screen.
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
To do a hard reset; just unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. If you wish to do a system reset, you have to enter its service mode option. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 30, 2013
Testimonial: "Thanks for the info. I tried your reset advice, but it did nothing to resolve my issue. I am afraid that the main board is probably fried. :("
  • Richard Givis
    Richard Givis Dec 30, 2013
    Prompt reply from this repairman! Thanks. Too bad the reset did not fix my problem.
LG 47LW5600 when turned on TV power light comes on and i hear the click, but nothing comes on on the screen. power light fads in and out slowly.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 04, 2016 | LG 47 47LW5600 47 3D LCD TV
My TV LG 47LW5600 IS BROKEN
Discard it and buy a new one.
Oct 19, 2016 | LG 47 47LW5600 47 3D LCD TV
My TV is frozen on BBC4 "media initializing" what can I do?
Power off the tv. Unplug it from the wall and let it set for a good 5-10 minutes for a hard reset on the tv. If you have a cable box then do the same to it. It sounds like the whole system needs a hard reset.
May 29, 2016 | LG Televison & Video
Lg 47lw5600 wont turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 05, 2015 | LG Televison & Video
Hard Boot LG Revalution
Please note that all data will be deleted from the LG Revolution as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your LG Revolution is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Revolution. Once the wipe is complete, the phone will reboot to its factory fresh state.
Your Welcome :D
Aug 29, 2013 | LG Cell Phones
My kindle is frozen. holding power switch for 15sec. did not work
Make sure you have enough battery life to support the kindle, because sometimes it stays in the frozen state if it detects you have little battery life.
If this doesn't work, press , , and keys simultaneously (This is it's soft reset)
The last resort I would suggest is to do a hard reset. Make sure your battery is charged to about an hour, remove the cord from your kindle. Turn your kindle over and open the back, you should see the small hole under the word RESET. Get a paper clip, unwind it and insert the clip into the hole CAREFULLY and press for about 10 seconds. The screen should be blank, and it will restart.
May 31, 2011 | Amazon Kindle Wireless Reading Device
Palm life drive frozen on "palm one "screen
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your lifedrive, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm LifeDrive Handheld
Televison & Video Logo
426 people viewed this question
Top Televison & Video Experts
