Question about Fitbit Facebook Apps
How do I sync my fitbit zip - Fitbit Facebook Apps
How do I sync my fitbit ulta
Bring your charged fitbit near to the plugged-in dongle or base station. You may need to press your fitbit button or tap it to wake it up. Then, Click the Fitbit Connect icon. Finally, Click Open Main Menu, and then click Sync Now. You may be asked to sign in, after which your fitbit should sync with your account.
If these steps do not work then please review the link below for additional trouble shooting tips.
Why isn my Ultra tracker syncing to my computer
Aug 03, 2016 | Exercise & Fitness
How do I charge my fitbit zip battery?
You cannot charge the Fitbit Zip as it uses a coin battery.
The Fitbit Zip runs on a replaceable 3V coin battery, CR2025.
It can be found wherever batteries are sold.
You can change the battery while not wearing hence counting steps. Fitbit Zip Battery Change
Mar 15, 2016 | Fitbit Zip Wireless Fitness Tracker
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How do I set the time on my fitbit?
After you charge it back up, you will need to sync your Fitbit, this Sync will update the steps
May 20, 2015 | Fitbit Zip Wireless Activity Tracker,...
How do I set the time on a Fitbit Zip?
  • The current time can be viewed on the Fitbit Ultra's display.
  • The time can be displayed in 12 hour format (e.g., 5:00 PM) or 24 hour format (e.g., 17:00). You can adjust this setting on the Edit Profile page, which affects the displayed time on the Fitbit Ultra, graphs, and input fields across the site.
  • The clock display can be disabled from the Fitbit Ultra setup screen.
Feb 15, 2015 | Fitbit Zip Wireless Activity Tracker...
Need help downloading a fitbit to my hp computer
  1. Go tohttp://www.fitbit.com/setup/and click theDownload Herebutton to download Fitbit Connect for your Force, Flex, One, or Zip tracker. If you have an Ultra, you should instead followthese steps.
  2. Once the download has completed, open the file and begin to follow the onscreen instructions.
    If you are on a Mac, open the dmg file. If it doesn't appear on your desktop, search for "Fitbit Connect" in Spotlight.
    If you are on a PC, run the .exe file from your download location. If it doesn't appear on your desktop, search for "Fitbit Connect" in the Start menu.
  3. Once the installation is complete, you will be presented with the Fitbit Connect Main Menu. SelectSet Up A New Fitbit Device.
  4. Account Setup:
    • SelectNew to Fitbitif you don't already have a Fitbit.com account.
    • SelectExisting Userto log in using your existing Fitbit.com account.
    • ou will be asked for a few details about yourself. This information improves the accuracy of your caloric burn and distance data. You can later adjust yourprivacy settingsto control which details are shared with others.
    • After filling out your personal information, you'll be asked which device you're setting up. Select the appropriate tracker to continue.
    • Plug the wireless USB sync dongle into your computer (this is the smaller USB device--not the charging cable), and bring your tracker near to it to begin pairing.
    • Tracker Pairing:
      • Force, One, or Zip: You will see a pairing number that appears on your tracker's display once your device has been located; enter this number on your computer.
      • Flex: Follow the onscreen instructions and rapidly tap the device when instructed, then confirm its vibration.
    • After clickingNext, your tracker will connect to your Fitbit.com account. This can take up to a minute.
    • Once your tracker has connected to Fitbit.com, you may be prompted to enter a greeting (depending on which tracker you have). This can be your name or any 8-character combination of letters or numbers.
    • When your tracker is linked with your Fitbit account, Fitbit Connect will notify you and present some basic instructions on using your device.
    • You can now log into your account dashboard to view your synced data.
      You will not need to repeat these steps once they have completed--you can simply login tohttp://fitbit.comto access your dashboard.Or Still having Problem Then follow Us For
      HP Support
Apr 24, 2014 | HP Office Equipment & Supplies
Fitbit login
h e l p I bought a fitbit zip yesterday, I am unable to sync as it does not recognise my email address how do I redo the email address and password please abronn@ozemail.com.au
Dec 09, 2013 | Facebook Apps
Facebook Apps Logo
27 people viewed this question
Top Fitbit Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Fitbit Facebook App Expert? Answer questions, earn points and help others
