Question about Minolta EP4000/5000 CS/PRO Copier
Reset error m2 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 1,294 Answers
M2 -waste toner box need to empty.
Displayed to indicated that the Toner collect count of the consumables counter has reached the set count.To reset select Count in the Tech.Rep.mode and acces the Consumables screen.Select the count of toner collect and press the clear key to clear the count.Place the copier in the Tech.Rep.mode by pressing the following keys:Stop-0-Stop-1.
Posted on Jan 03, 2014
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Mintenance call m2
M2 means Time to replace your consumables (drum,developer,cleaning blade,drum charge assy & cleaning pad) after replacement reset it to Tech rep mode.
Oct 28, 2014 | Konica Minolta Office Equipment & Supplies
What's carry out maitenance mean its showing on my
M2 supper automatic have a programmable maintenance schedule set up by the technician whom installed the machine (if this is the original location.) Call your vendor as it must be reset and cleared by a certified technician. The machine will lock out if not cleared. Some machine s will continue to be operational but needs to be reset every morning after bypassing error. Naturally continued use of machine will eventually fail from a more serious problem as errors are ignored.
Sep 13, 2014 | Coffee Makers & Espresso Machines
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
How do I reset the calculator after installing new
[OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
To clear memory M1 : Store 0 in 1
0 [STO] 1 clears M1
0[STO] 2 clears m2
0 [STO] 3 clears M2
Feb 03, 2010 | Texas Instruments TI-30XA Calculator
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
129 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
