Question about Kyocera FS-1035MFP
Set up a Kyocera copier
The copier will not scan and send an e-mail
  • Kyocera Expert
  • 337 Answers
You have to make sure the mfp is set up on the local area network, then set up the smtp information in the command center. See THIS LINK for instructions or consult kyocera support site or your install disk for users manuals. it is very similar to setting up outlook.
Posted on Jan 01, 2014
3 Suggested Answers
support741
  • 337 Answers
SOURCE: Failed to send via SMB
What model copier? What error code? What OS?
Posted on Jan 30, 2013
fivemayur
  • 414 Answers
SOURCE: I have a Kyocera CS 1820 copier which has a failed connection on my MAC MINI - MAC OS X Lion. When I send a scan to my computer i get an error code 2102
I think Change the SMTP port from 25 to 587 hope i'm right
Posted on Mar 06, 2013
Guyscan you help me configure Scan to email from a Kyocera Copystar 250ci printer what settings will i look around to configure scan to gmail or other email clients
You need to find where to enter the settings for an smtp server. (simple mail transport protocol) Most internet service providers allow clients to use their smtp server. For instance, for Shaw in Canada to smtp server is mail.shaw.ca. Some will require authentication in which case you will need to have a valid account with that provider.
Jan 22, 2016 | Kyocera Office Equipment & Supplies
How do i connect to the scanner.I have this connected for the printer,now i need items scanned to send e-mail don't know how to do this
It all depends on how your set up is. If you are connected through USB, you will need to download the twain driver from the Kyocera website. Then you can utilize any scanning program that you wish to collect the document image.
If you are connected through ethernet, it's a little more complicated. The first choice you need to decide is what you want done with the document image after it has been acquired. There are three main choices: Upload to FTP server, Send to a folder on a computer through SMB, or email.
All three of these options are obtained through the Kyocera Command Center software installed on the printer. Point your browser to http://192.168.2.10/ and you can login. If it asks for password, the unit ships with password "admin00", so that should get you in unless someone changed it.
You can adjust the settings through this screen. Head over to the "scan" tab, and you can put in the information for whichever way you want it. If you decide on Email, you will notice at the bottom of the page a link to set up the SMTP options for sending the emails.
Another note with email: you will need to set up a DNS server in the TCP/IP section under "Basic" settings. If you don't have a DNS server on your network, you can utilize universal ones. I recommend using Google's DNS servers (8.8.8.8 & 8.8.4.4)
Sep 21, 2011 | Kyocera FS1128MFP AllInOne Laser Printer
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
When trying to send a scan to email, it says it is unable to connect to the SMTP?
You have an incorrect setting in the configuration part of the machine. The SMTP setting is for your connection to your OUTGOING mail server. This may have the wrong address setting or the authentication is not configured properly or it may need to go out on a special port. Talk to someone familiar with your e-mail settings. All I can help you with is to tell you where to look.
Jul 19, 2011 | Kyocera COPYSTAR CS-2050 Printer
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera cs 1820 error 2102 using ftp
I reset the IP adderss to another printer on the network and it worked so it looks like not all printers are compatable
Jun 17, 2009 | Kyocera Copystar CS-1820 Black and White...
I have a Kyocera CS 1820 copier, scanner, fax machine and I can't figure out how to geet it to scan to pc. I have installed the drivers from the kyocera site and still no luck......
Make sure that you downloaded the correct drivers....Etc... (x64) vs (x86) also make sure you have the proper script # driver ... Etc... #5.1 vs #6. You will want to completely uninstall all the old drivers, shut down your computer --- do not just reboot, reinstall all the new drivers,and after your computer is done rebooting – shut it down and restart. Also make sure that you and the designated file set up on the computer, it needs to know where to scan the document and send it to.
Dec 23, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
Kyocera 2550 Scans but how do I OCR?
You can find documentation form Kyocera Printers here, though it barely mentions anything about their OCR feature:
http://usa.kyoceramita.com/americas/jsp/Kyocera/home.jsp
The OCR feature is only an image quality setting, producing a more black and white high contrast image rather than a grey scale image.
I'm using our Kyoceras to email the images to a server where "send mail" processes the image and runs OCRopus, an open source Google funded OCR project, to read information from the scan.
I'm finding there are many Virtual ReScan solutions, like Kyocera's OCR feature, VRS software produces OCR optimized images, though I haven't found an open source VRS project.
Jun 08, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera FS-1035MFP Logo
69 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
