What is an external modem - Computers & Internet
  • 79 Answers
It is a gateway between the computer and your service providers internet service either by phone satellite or cable like for your tv it is used to allow the computer access to the internet
Posted on May 19, 2009
D2600 router modem will not connect to internet unless I run it through an external modem?
Have your internet provider provision(register) the D2600 as your primary modem.
Jan 04, 2014 | NetGear Computers & Internet
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
Can I get a external modem for my inspiron n4010 and where would it plug in?
Hi
Yes you can get an external modem for your inspiron. Most external modem devices can be plugged in using the USB ports in your laptop.Thanks
Feb 19, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
How do you replace an internal modem on Dell Dimension 5100 desktop? Can we replace it with an external modem? Do you have to remove the old internal modem before you can replace it with an external modem?...
yes you can replace it with an external modem or you can purchase a PCI card modem and install it. The old internal modem does not have to be removed, but if it helps you can uninstall the drivers for it.
Aug 03, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Need a driver for vista 64 bit ,have an external modemdx m300 dynex
I searched the Dynex website & found this page:
http://www.dynexproducts.com/p-494-dynex-56k-v92-usb-external-datafax-modem.aspx
This type of external modems is no longer supported by Dynex. It is now a discontinued product.
Jul 13, 2009 | Dynex (DX-M300) Modem
My laptop dont have internal modem i want to connect my laptop via external usb modem with existing telephone connection
Here is one source for a USB external modem. I do a lot of business with Tiger Direct and they are competitive and fast shipping. There are many other vendors as well. A google search for "USB external modem" will get you going.
May 01, 2009 | Dell Inspiron 1525 Laptop
Need help picking an external modem for an old Dell Insprion 2500
Any computer capable of running Windows ME is capable of supporting any external modem.
In the past, for "internal" modems, there were "hardware" modems and "soft" modems.
The "soft" modems had 50% of the hardware of the "hardware" modem,
and the rest of the "brains" of the modem were embedded
in a software device-driver that gets installed into Windows.
Fortunately, most external modems are *NOT* such "soft" modems.
There do exist external modems that connect to a USB port,
and external USB wireless-devices, if you want a higher-speed connection.
Apr 27, 2009 | Dell Inspiron 2500 Notebook
"USB external modem and an acer one
It should work fine as long as the external modem has a USB connection and drivers for the operating system you're running (Windows XP or Linux).
Jan 19, 2009 | Acer FM56 ITU/2 (91.AC001.209) Modem
Pc modem help
Yes, they do make an External Modem. You can purchase a an external modem and any local computer store or even online.
It can easily be hooked up with a power cable which should be included and a phone cable or a dsl cable depending on if you are getting a dsl modem or a dial up modem.
Either way, the external modem should come with easy to follow directions.
I hope this helps.
Please post a rating if I have answered your question.
Good luck.
Mac =)
May 20, 2008 | Computers & Internet
Windows Vista
  Yes all the external modems are compatible with  windows Vista
Oct 18, 2007 | Zoom /Modem V.92 EXT 3049 (3049-00-00C)
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
