Question about Thermador MBES Microwave Oven
Microwave keeps turning off
Whats wrong with my thormador microwave oven? Model MYBS 30" 1100 watt 10 power. It accepts all commands but turns off after 3 seconds into it?
Master_Tech
  • 770 Answers
SOURCE: microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Posted on Jan 24, 2008
SOURCE: Thermador MBY microwave
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Posted on Jun 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: thermador microwave from oven/micro/warming drawer
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Posted on Aug 21, 2008
grandadfixer
  • 99 Answers
SOURCE: Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Posted on Oct 11, 2008
  • 72 Answers
SOURCE: microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Posted on Feb 04, 2010
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
Frigidaire FMV145K 950 Watts Microwave Oven makes LOUD noise when turn table turns?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 25, 2011 | Frigidaire FMV145K Microwave Oven
I have a kenmore microwave hood combination. Model 721.80419. How many watts does this microwave work on?
It has a specified power rating of over 1000 watts.
There are 10 settings of power and is prrogramable.
get your manuals from the following link:
http://www.hammerwall.com/Download_Manual/59565/
Sep 18, 2010 | Kenmore 80412 Microwave Oven
MMV4184A 1000 Watts Microwave Oven: My microwave turns on but does not heat the food. ...
heatman101
fsjf
May 18, 2010 | Maytag MMV4184A 1000 Watts Microwave Oven
63252 / 63259 1200 Watts Microwave Oven: Turns on but,wont heat up...
heatman101
hhgds
May 07, 2010 | Kenmore 63252 Microwave Oven
Turns on but doesn't heat only a year old LG LRM1260SW 1200 Watts Microwave Oven
I have had the LG model lrm1260sw microwave for 3 years. Recently it quit heating. I found the problem was the soldered grounding lug connection on the power transformer had lost circuit continuity and failed. One of the secondary coils on the power transformer, red wire / bare copper wire, is connected to ground / chassis. I cleaned the lug connection and added a length of wire twisted together with the bare copper coil wire and soldered to the grounding lug. I then grounded the extra added length of wire to another chassis ground point. Make sure the transformer to chassis mounting screws are tight also. Now the microwave oven works like new again.
Feb 27, 2010 | LG LRM1260SW Microwave Oven
The microwave turns on. The microwave generator
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 29, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Squirrely Microwave
heatman101
Oct 24, 2008 | GE JVM1850 1000 Watts Microwave Oven
Power level again
It is probably a 700 watt model. Most ovens have 10 power levels, ranging from 10% to 100%. Normally you press POWER LEVEL, then press 1 for 10%, 2 for 20%, etc., then press START or COOK to cook. We could not find exact information on this model.
Mar 25, 2007 | Samsung MW4350W Microwave Oven
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
Thermador MBES Microwave Oven Logo
117 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
