Question about Air Tools & Compressors
Are there smaller, portable, air casters? - Air Tools & Compressors
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 54 Answers
Yes. However they might not be your best solution. Portable air casters usually work best for very short distances and infrequent moves. This means that if you need more frequent moves or travelling longer distances, you will need continuous compressed air supply (high pressure nitrogen bottles), which would make the whole cost more than it's worth.
Posted on Dec 30, 2013
Does this chair have breaks?
This chair doesn't have breaks but it comes with casters that will hold it in place. Each caster, which should be placed on the floor where you want the chair stationary, is three inches by three inches. The casters are included with the chair/cammode.
Feb 16, 2014 | Generic Lightweight Portable Shower Chair...
If air caster stops creating air cushions under the load, will it suddenly drop?
No. Even if the air supply suddenly shuts off, it will take a while before the air inside the air caster completely ends. This way the load will not suffer from sudden shocks. However, after the load is resting on the landing pads, it can hardly be moved.
Dec 30, 2013 | Air Tools & Compressors
Does my floor have to be perfectly smooth to use air casters?
It is better to use air casters on smooth, nonporous sourfaces as cracks or bumps interrupt the correct flow of air and might impair the air cushions. However the surface doesn't have to be perfect like glass. A standard concrete warehouse or factory floor are usually good enough.
When was the air caster invented?
air casters were invented in the late 1950s by British Hovercraft Corporation
Jan 30, 2013 | Air Tools & Compressors
Can anyone explain to me what an air caster is?
An air caster is a pneumatic lifting device used to move heavy loads on flat, non-porous surfaces. its like a hovercraft, it lifts something about 1 mm off the ground with compressed air
Need replace a wheel
Home Depot sells casters (wheels),, pull one off and take it with you .
that way you'll find a match... the caster will problably have a post going into the leg. just pull it down to remove.. Good luck.. Geoff
Mar 09, 2012 | Delta Portable Baby Bassinet
Broken caster
Your local home improvement store will have a caster that you should be able to glue onto the bottom part..
May 28, 2010 | Sharp CV10NH Air Conditioner
Broken wheel roller on a PAC-121 portable air conditioner
Yes, you can. The caster part number is 2040-0142 and can be found at some online retailers.
PartsGuy.com
Appliancefactoryparts.com
Feb 18, 2009 | Comfort-Aire PAC-121 Air Conditioner
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
Air Tools & Compressors Logo
448 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
