Question about Symantec Procomm Plus 4.8 for PC
Procomm plus diaplay file location
Telephony device has been removed...
That means you took the fax modem out, or the drivers are missing
Nov 30, 2013 | Symantec Procomm Plus 4.8 for PC
Deleted files inadvertently, how do you recover?
try this & see if it will take care of the problem
Go to the control panel
Go to programs
Go to accessories
Go to system tools
Go to system restore
Click restore my computer to a earlier time
& pick a day before you uninstalled the programs
Sep 22, 2011 | Symantec Procomm Plus 4.8 for PC
Print screen to printer does not work?
try to clear your browsing history, and then check the printer if it is disconnected or disabled.
Mar 02, 2010 | Symantec Procomm Plus 4.8 for PC
Printer only sends paper to tray 1 when printing from procomm...
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
Apr 09, 2009 | HP LaserJet P3005n Printer
Unable to print screen shot
Check reg key:
HKEY_CLASSES_ROOTLocal SettingsSoftwareMicrosoftWindowsShellMuiCache
value name: @%SystemRoot%System32SnippingTool.exe,-15052
value data: Capture a portion of your screen so you can save, annotate, or share the image.
Feb 06, 2009 | Symantec Procomm Plus 4.8 for PC
My procomm plus issue
Procomm Plus and norton 360 are compitable to each other but r not not compitable to work on your operating system .u will just need to format your pc and clean the Procomm Plus files from it and then also delete the norton 360 from your operating system.and then u will be able to reinstall the Procomm Plus after formatting the pc.then instead of norton 360 install any other antivirus software like symantec or avg
Dec 10, 2008 | Computers & Internet
Y-Modem file transfer aborts
Otie, Is this the only unit having trouble? Have you checked your firewall settings? Not knowing the error messege I will just throw my 2 cents in... Have there been any updates to the XP Pro? Has there been any ProComm updates that may have affected the machine. You may need to reset and reconfigure the modem. There could even be some kind of interference at the Telco Office. Just some thoughts, Tim
Feb 02, 2007 | Hawking (UC232S) Serial Adapter
Symantec Procomm Plus 4.8 for PC Logo
26 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
