Question about Hardware & Accessories
Aqua sys 2 dial timer 1019531
It won't automatically turn off
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Intermatic dial doesn't automatically switch sprinklers
1) Trippers can wear down. Transformer can go bad if model has 24Volt output. Relay can go bad.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
2) Add a comment Feb 2013 with model number, and include if this is new timer or older timer that worked before and stopped working.
Feb 10, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Dishwasher won't start
its the timer in the dial replace it and it will work fine yes its worth fixing
Dec 03, 2012 | Kenmore Dishwashers
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
Jul 27, 2011 | Intermatic R8806P101C -...
We have the Noma Exterior Mechanical No instructions. Shows on and off/dusk and then the hours. Do you turn to dusk and then the hours how do you set it to come at dusk then turn off 6 hours later?
Identify timer on following page:
Page shows instructions and troubleshooting.
That being said, if your timer has a dial with 2 4 6 8, then following instructions probably apply:
Timer turns on automatically at dusk,
Rotate dial to select when timer will turn off.
In your case, rotate dial to 6, and then timer will turn off 6 hours later.
Make sure to keep timer turned away from lights, or where car lights might reach photo-eye located on front of timer.
If timer is exposed to light, it will turn OFF, and then blink back ON few minutes later.
When timer turns ON again, the 6 hour countdown starts over.
Dec 22, 2010 | Garden
I want to use just the pm of the timer....for xmas lights....I see how the arrowis to be put on the 5 .....thats when i want them to come on....and 9 later in the evening....where do i put the arrow for...
You posted under The Woods/Coleman 2001 timer.
This is same as Westek TM14DOLB, Sylvania SA200 and similar to GE 57696.
If this is not your timer, add a comment with description and brand of timer.
Also see Woods timers and manuals to help identify your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
This particular timer turns ON automatically at dusk.
And then you set the dial for other options as follows.
Dial set to ON > timer ON full time
Dial set to OFF > timer OFF
Dial set to 2 4 6 8 > timer turns OFF 2 4 6 8 hours after dusk
Dial set to Dawn-dusk > timer turns OFF at dawn.
Dec 12, 2010 | Woods Outdoor Lighting Timer
How to program a intermatic outdoor timer/photo control hb51rc
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
Automatic cycle dries but doesn't turn off GE
Check for bad motor timer. Attached to dial control. Test by turning dial to timed position without starting dryer. Dial should return to off. Timer is available online.
Jul 11, 2009 | Dryers
Hardware & Accessories Logo
41 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
