Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
How do I switch flame on prothrm boiler - Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Sime boiler pilot light
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
Apr 07, 2014 | Water Heaters
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
When my boiler pilot light starts up it kicks out straight way and knocks off the boiler seems to have no faulty parts
Pilot lights have a metal detector just above them, which heats up when the flame is on. If that is not switching fully, Boiler will think no flame and close down. It is a safety feature, but if faulty will stop boiler firing, might just need adjusting, but may also need to be replaced, not really recommended as a diy job
Mar 04, 2013 | Water Heaters
Boiler working but radiators cold
Seems that you may have bad circulation pump.
Feb 24, 2013 | Water Heaters
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
When you turn on hot water tap the boiler fires up hot water for a few seconds the water becomes cold the boiler flame goes out then fires up again. when the heating on the flames stays on then off then on...
To avoid having a flame in the absence of water flow, the device you mentioned, 'diaphragm,' detects if adequate water is flowing to avoid a dangerous condition. Check on the housing of it for an adjustment screw; it may have a dot of sealant on it since these normally can be adjusted. It sounds as if it is misjudging the quantity of water flowing through and causing the annoying cycling.
Dec 17, 2010 | Water Heaters
Hi, im having problems with my hydroline b24 boiler, it will fire up but only for a short time then it stops and a fault light come on (flame or gas failure) i dont think its the gas pressure as the burner...
Switch off the boiler at the mains, remove the front panel and 'lower' the display unit/pcb. Locate the (blue) sensor in the condensate trap (rear left hand corner of the boiler). Remove the sensor and dry the area around the probes which are on the end of the sensor which enters the trap. Restart the boiler - if it runs correctly you have a problem with your condensate overflow (as did I). Good luck.
Dec 19, 2009 | Water Heaters
Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Aug 31, 2009 | Water Heaters
Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
22 people viewed this question
Top Protech Systems Water Heaters Experts
paulcarew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
