Question about GE JVM1440 Microwave Oven
Whirlpool over the range microwave
I do not have the model number at this time.
My microwave has the tendency to start running by itself. While it is running I will then press buttons and it shows on the screen that the door is open and it does not allow me to use any settings. Sometimes I push on the door and it stops running and then I am able to use the settings.
I understand that it may be a door problem, but I am confused how it thinks the door is open and it still runs. Please help, whether it be a door or a configuration problem.
Thanks Dana!
  • GE Master
  • 9,149 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
Posted on Oct 22, 2007
Have a Whirlpool over-stove microwave. Can set time but then it scrolls between AM & PM. Cannot find how to set the AM/PM portion, and completing the time set.
Which microwave model do you have? Most of the Whirlpool microwaves that I know only have a 12-hour clock. They do not indicate AM or PM. To set the ones that I know, press Clock. Type in the current time in a 12-hour format. Press Clock again. The only model that I find quickly that has an AM/PM option is the GH7208XR. On that model, start with the main menu displayed on the LCD screen. Touch Settings and Info. Next press Clock. Then press Adjust Time. Follow the instructions to set the time and the AM/PM setting. I'll assume you use the +/- buttons. To hide the clock, get to the Clock Screen. Press Adjust Time and Hide Clock to return to the main menu. See these two pages of the manual for this model: https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=9#manual and https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=12#manual
Current Whirlpool over-the-range models sold in the US are listed here: https://www.whirlpool.com/kitchen/cooking/microwaves/over-the-range.html . Other Whirlpool appliance manuals are available from the Owner Support page: https://www.whirlpool.com/services/manuals.html.
I hope this helps. Please add a comment with the model number for a more accurate information on setting the clock. The model number should be inside the microwave on the rim. Usually it's on the bottom of the door frame near the door hinge.
Sep 19, 2018 | Whirlpool Microwave Ovens
I have a whirlpool gold over the stove top microwave that control panel starts beeping and setting itself. How to do I fix model gh7208xry-3?
This answer is for model GH7208XRY3. The support page for your model is here, and you can view or download the owner's manual and installation instructions.
The exploded view with parts list is here.
You will need to order either the door control assembly, part number W10115584 for $280.35 from the Pros here, OR you can order the whole door. It costs more, but it easier to replace. It is part number W10327332 and runs $428.68 from the Pros here. (Prices subject to change)
Feel free to contact me for further info.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Whirlpool Microwave Ovens
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 04, 2011 | Whirlpool Microwave Ovens
Remodeled kitchen axly 4 years ago. Whirlpool MT2145SJ (number taken from use and care guide) microwave installed above range. About month or so ago, the fan quit running during the microwaver time, and...
Hello, unfortunately we are not trained technicians and we cannot advise you how to repair the unit. We would always recommend resetting the appliance by removing the power for 2-3 minutes. If that does not correct the problem we would suggest having a certified technician properly diagnose the problem that you are experiencing. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased your appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 18, 2017 | Whirlpool MT2145SJ 1100 Watts Microwave...
Whirlpool model number mh117oxsb-o Microwave shuts down after a few seconds,
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If so, then your magnetron may be failing or the cooling fan itself may be.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
If your under hood lamps recently went out, that surge could have damaged the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and part ordering help
here.
I'd recommend that your bookmark this link to your favorites.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Jan 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My microwave turns off when I start it
its the program bord inside your microwave playing up and to be realy honest its realy not worth paying out good money to get it fixed even if you could get the new bord,,,its better to just buy a new microwave there so cheap now you can pick them up for less than £50.00p and it would cost you all of that just for the repair man to come and look at it,,,,why do you think they all drive round in big cars?
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Dec 08, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
