Question about DFI 865GV-MLV (P865GVMLVREVC) Motherboard
CPU turns on but no screen
Hello, For some time, I am unable to use my computer, because when I turn on my pc, the screen displays "No Signal". CPU running normally, the fan also and the problem just the screen or cable connection because I have test it on another pc and it works normally. so if anyone can, give me some advice.
  • DFI Master
  • 16,194 Answers
If you have a seperate video card in that motherboard. Take it out and reseat it, then try again. If you have a spare video card, try that.
Posted on Dec 30, 2013
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
Aug 02, 2014 | Acer Veriton Computers & Internet
Turns on with no display and beeps
The motherboard is unable to talk to the computer's video card , RAM, or CPU. you'll need to open the case up to troubleshoot and re-seat the components/figure out what's wrong. (or of course bring it to a computer repair shop if you don't know what you're doing inside the machine).
Jan 22, 2014 | Compaq Presario S6300NX PC Desktop
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
No display
Try replacing the VGA cable if it is not hard wired to the screen. Check that the CPU is not sending an out of range signal (i'e. To Low / To high) Hope this may help.
Feb 17, 2010 | Hanns.G Corporation HW173D Monitor
My monitor suddenly lost signal and hasn't returned
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
Jan 25, 2010 | eMachines T6534 PC Desktop
Monitor only has a black screen, when i turn it on the power button turns from blue to orange and the screen says no signal and then turns black
First open cpu cabinet Refix RAM memory .
Then pull cmos cell from motherbord for 10 minutes so all settings are defaults.
Then when power up the computer press F8 key then enter in enable vga mode.
Then go to control panel and display proeprty then settings change screen resolution to 1024*768 then apply and ok.
Then restart the computer.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | E-Machines eMachines Desktop PC
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
This would usually indicate that there is a problem that is causing your computer to not boot correctly all of the time. What you have described could be many different problems and without more information I cannot say which one it is.
1. Hard drive. I have ran into Hard Drives that for some reason do not start up correctly right away when you put power to them. This can cause the initial startup to hang possibly indefinitely.
2. Video Card. Something probably firmware is causing your video card to not start up properly when power is first applied.
3. PSU. The power supply could cause similar problems if it cannot supply enough power because the highest power draw is when you first turn on the computer. When you push the reset button the power is already being supplied to most of the components and the ones that did not have enough power to start properly before can do so now.
4. CPU. If the CPU has some minor problems it can cause similar problems. In any case to fix it you can try clocking down the CPU but you are better off replacing it.
5. RAM. I have had similar problems with RAM. Clocking down the RAM fixed the issue.
6. Settings in BIOS. I would check to make sure the setting for init display on boot is set for PCI-e.
Nov 06, 2007 | XFX GeForce 6200 Graphic Card
DFI 865GV-MLV (P865GVMLVREVC) Motherboard Logo
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
