Question about Frigidaire FAFS4473LA Washer
E58 error does not spin
I WANT A INSTRUCTION MANUAL TAPE RADIO CD JVC DR-E58 COMPLETE INSTRUCTION MANUAL
Hi there... ABDOU,
Nothing here in the UNITED STATES...
(fixya: San Mateo, California) but found a SINGLE entry
from the GLOBAL Search...
Original Service Manual JVC DR E58 BK DR E59TN eBay
Hope this helps
Carnac the Magnificent
Nov 15, 2017 | JVC Car Audio & Video
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
Error code E58 on insight E12108W washing machine .....what does this mean and what should I do?? Thanks
Motor is drawing too much current >5A,
could be motor defective, wiring or inverter board.
Dado
Sep 20, 2014 | Electrolux Washing Machines
What is E58
Good Afternoon Friend,
I understand you are receiving an E58 code on your Frigidaire Affinity washer, model# ATF8000FE. The E58 states that it is a high current on the motor phase. This could possibly be a false code, as well. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF8000FE
What is electrolux front load washer E58 error code
Good Morning Friend, I am happy to assist you!
I understand your Electrolux washer is getting an error code E58. It could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps! - Z
Jun 04, 2014 | Frigidaire Affinity ATF7000E Front Load...
E58 Error Code
Hello Walter, thank you for your post!
Hope this proves helpful!
Jan 28, 2014 | Electrolux Washing Machines
Error code e58
Hi Grace, thank you for allowing me to assist you. Regrettably, an error code E58 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing.
Aug 04, 2013 | Frigidaire GLTF2940ES Front Load Washer
Front load electrolux washer wont spin showed e58 now after attempting system clean e 57
According to the alarm code E58 is usually a washing machine with inverter and means problem with inverter board or motor or wiring between inverter-motor.
Could be:
E58 - Inverter is drawing too much current (> 4.5A).
Abnormal motor operation (overload).
Motor-inverter wiring faulty.
Motor faulty.
Inverter board faulty.
E57 - Inverter is drawing too much current (>15A)
Motor faulty.
Dado
Feb 10, 2013 | Electrolux Washing Machines
Much loved old J.V.C. unit
Sounds to me like the belt drive is slipping!
Need to open her up and check tightness of belt and probably try to buy another one which will be tighter!
Mar 21, 2008 | Audio Players & Recorders
Frigidaire FAFS4473LA Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
