Question about Toshiba Vintage Am Fm Stereo Headphone Receiver Rp-2020
Schematic required for Toshiba vintage receiver RP2000F
FM band very weak
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
I require an ariel for model ICF-S10MK2. I live in
I just want to know where to purchase an ariel. Could please advise me who would I approach here in Townsville North Queensland.
Thanks. Don.
Oct 07, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
FM output
I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
Aug 23, 2008 | Audiovox Xpress Satellite Radio Receiver...
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
I have a Westinghouse tube radio, AM/FM table model, uses a selenium rectifier. I need a schematic for this radio, do not have a model number, but chassis number is 240635. Would appreciate your help.
Hi driggins
Wondering if that may be the serial number that you have quoted. Most Westinghouse radios that I have been able to find are allocated model numbers as WRXXX
If it has a solid state rectifier then it will be post war vintage at least.
Are there any other identifying marks on the radio?
regards
robotek
Jul 13, 2008 | Audio Players & Recorders
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Toshiba Vintage Am Fm Stereo Headphone Receiver Rp-2020 Logo
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
