Question about Canon NP 6230 Copier
Error 212 on Cannon 6230 ? Printer comes up with this error and the operater turns off for a while then powers back up to resume. Sounds like the fuser.
    President:
  • 272 Answers
E212 Lens sensor or motor problem
remove the glass, check to see if sensor is out of place. Turn off copier move lens by hand and turn on does lens move, yes motor is most likely O.K.
does it stop at the sensor and give code? yes replace ( or swap sensor) does it still do it? No? replace bad sensor. Let me know if you need anythinf else~
Posted on May 19, 2009
How do i reset the mp252 cannon printer ink absorber error?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Thanks.
Feb 10, 2015 | Cannon Office Equipment & Supplies
"Waste ink tank almost full"
Here is the reset process. You need to carefully follow the steps for it to work. Not to defend Canon but without the waste ink counter you will at some point end up with ink leaking from the printer.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
I hope this helps.
Mar 21, 2011 | Canon Office Equipment & Supplies
I have cannon ip2772 printer which has an error code 6000. Please help me solve the problem. thanks
Use This
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Then My is Not Power On.............
Mar 09, 2011 | Office Equipment & Supplies
Error 6502
Dear Asker
how would i know this error is for which printer so i am assuming it's cannon.
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Feb 28, 2011 | Office Equipment & Supplies
Ink absorber is full on cannon pixma mp160
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
But some time when you get the chance do clean the waste tank out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Canon PIXMA MP160 All-In-One Printer
I have a Cannon Pixma MP150 printer. I am
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cannon MP830 error message 5Boo waste ink container full .Is there way to fix it?
Dec 02, 2009 | Cannon Canon i960 Photo Printer
Cannon mp 130 waste ink absorbe is full
Oct 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon NP 6230 Copier Logo
253 people viewed this question
old marine
old marine
