I AM WORKING ON A MONITOR, IBM 9513-AG1, AND WHEN I PLUG IT IN, ALL I GET IS FLASHING AMBER LIGHT. I KNOW THAT USUALLY MEANS BAD CAPS, BUT THAT IS NOT THE CASE. I HAD GOTTEN IT TO WORK BEFORE, BUT HAVE NOT WORKED ON IT IN A LONG TIME. COULD SOMEONE HELP DETERMINE THE PROBLEM? THANKS!
Hi, question... How do you open the monitor?
Hi..check properly the CPU then unplug the monitor and see the message (Signal out of Range) if you see this message from your monitor so its working,so the problem is on the CPU.if the CPU not working remove all the memory then make a clean and video card..thanks and good luck..have a nice day..^_^
