Question about Samsung Televison & Video
White dots on screne. wierd noise when starting up
I have a HL-S5086 DLP TV. In the past week two small white dots have appeared on the screne and haven't gone away. There is also an occational delay when I'm turning on the TV, and it makes a noise like something maybe going out in the back. What is the problem??
  • 431 Answers
Hi I am vortash weird noise would you say it was a fan or that type of sound it could be your colour wheel . the spots may be particles of debris from the wheel being amplified by the light and the lens .. without looking it.s hard to say .. if the sound is coming from the rear it may be electrical arcing from the lamp ballast or a warped fan blade .. you may have a faulty relay and that is clicking repeatedly .. as I say without looking it is difficult . If You have electrical Knowledge .. and are safety trained you may be able to find the fault yourself.. but it is doubtful that you could repair it as most of the components in a DLP TV are surface mounted on the circuit board and you need specialist equipment to service and solder them .. about the only thing you could do would be block replacement of a circuit and that may prove expensive if it was not that one that caused the fault in the first place . With these units about the only user serviceable component is the Lamp .do not try to measure the voltage at the lamp socket voltages here are in excess of 12,0000 volts on initial spark up . if you don't have a manual for this set I found one on this site http://www.safemanuals.com it is listed as the HL-S5686 same model different case but your model is listed in the manual .. if your going to try and repair it you can find a manual here but it is $19.50 and you may be able to find one to download off Bit torrent free http://www.eserviceinfo.com I hope this helps good luck .. Regards Vortash
It is strongly advised that unqualified personnel do not attempt to repair High Voltage equipment but leave it to qualified engineers ..
Posted on May 19, 2009
I have a Samsung 56 inch Television. This morning there are 3 white small spots on the screen. It looks like there is another fourth white on the upper right hand side also. This is model #...
Mine started with only one small white dot..... just a week ago, now I have a freakin constellation!!!! (at least 30) . I am gonna call samsung today to see if they will cover this even though it's out of warranty. I believe it to be the micro mirrors
Sep 22, 2010 | Samsung DLP HL-P5663W 56" TV
White spots appear about 8 in 2 weeks will it keep getting worst all at once or over along period of time
yes it will keep geting worse the dlp is is going bad the mirrors on it are getting stuck they may appear as black dots or white dots. the dlp ic needs to be replaced
Jan 29, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on Samsung 50* Model
Yes, It is problem with DMD module in light engine that will be replaced.
Hope Samsung will help you in replacement. Please update about outcomes.
Thanks.
Sep 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on 50in dlp samsung
This is caused by dust or dirt in the Optical Block. Only a good TV Tech can solve this problem.Call one for an estimate.
Aug 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Televison & Video Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
