Question about Hyundai Car Audio & Video
Radio pin code enter
What is the radio code for hyundai elantra 2002
voodoomox
  • 1689 Answers
SOURCE: 2002 Hyundai Elantra Check Engine
the error was resolved in the link below, please check the last post of Sith.
http://www.hyundai-forums.com/t28310-1997-elantra-code-p0455-help.htm
hope this will help you resolve th issue you have too.
Posted on Aug 17, 2008
  • 115 Answers
SOURCE: P0139 code for a 2003 hyundai elantra. What is this code?
Hi the code P0139 is Bank 1 sensor 2 lambda sensor fault ,possible wiring or sensor fault even if you replace the sensor you need to have the MIL lamp turned off by a Diagnostic machine,it is possible you have another fault such as poor Catalytic converter efficency giving the same fault code ,Would recomend you get the car checked and read the "live" data as the car see`s it to make an accurate diagnosis and cure
Posted on Jul 10, 2009
ghost45
  • 1280 Answers
SOURCE: 2002 hyundai elantra radio and dome light not working
Then 1, bulbs are burned out
OR 2, the wiring is faulty.
Posted on Nov 04, 2009
Testimonial: "thanx for the solution. took the car to a repair shop and was told that the wiring was faulty. had the car rewired."
  • 184 Answers
SOURCE: 2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
Posted on Feb 11, 2010
  • 171 Answers
SOURCE: how to replace 2002 hyundai elantra hub and bearing
With the car on ground, break loose the drive-axle nut, and the wheel nuts , than jack up the car, support it properly, remove the wheel ,remove the axle-nut.
Remove the brake caliper assembly-- support it properly.
Remove the two bolts that hold the hub bracket to the Macpherson strut assemble, remove the lower arm ball joint and remove the steering tie- rod ball-joint attached to the hub bracket. That's it.Slide off the hub /with the bracket off the drive-shaft.
Follow steps backwards to assemble back.
Posted on Apr 09, 2010
2003 Hyundai Elantra Radio dead
Have you checked your handbook? It probably has a code that must now be entered to activate. Its an anti-theft measure
Nov 10, 2013 | Hyundai 2003 Elantra Radio / CD Player...
My battery died so now the radio needs the code entered but i don't have the pin code is there any way i can get it to work with out the code?
Contact a Hyundai dealership in your country and discuss with them. They are usually able to give you the reset code by you giving them your VIN / Chasis number for your vehicle - Assuming you still have the factory fit stereo.
Jun 09, 2011 | Hyundai Elantra 2007-2008 Radio Dash Kit...
Changed the battery now no radio havent got a code now what
what kinds of car is it? i work at batteries plus and sometimes when we switch out car batteries the radio locks up until you enter the code which is usually in the owners manual or theres a sticker located in the car somewhere. just google "radio code for" the make, model, and year of your car.
hope this helps
*~Never Give Up~*
Sep 29, 2010 | Hyundai Motor 2002 Elantra
2002 hyundai elantra factory stereo wiring colors
2002 Hyundai Elantra Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Gray/Orange
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Yellow
Left Rear Speaker Wire (-): Black
Right Rear Speaker Wire (+): Orange
Right Rear Speaker Wire (-): Blue
Jan 25, 2010 | Car Audio & Video
I have a 2002 Hyundai Elantra, I changed the battery , now I need the reset code for the CD player HM 5064. I cannot find my manual. Can anybody help?
Normally the Audio (Radio CODE) is noted in the owner's manual. If you don't have it, you must contact Hyundai Motor America and give them the Vehicle VIN number... they may then (possibly) be able to give you the CODE.
Nov 01, 2009 | Hyundai Motor 2002 Elantra
Oct 22, 2009 | Hyundai Motor 2002 Elantra
How can i finde a pin code for hyundai elantra 2003 please
dear friend-i assume it is not a hyundai radio as they do not come with codes,go on the net to find manu facturer,they must have the code,have the serial no on the radio ready.
Jun 30, 2009 | Hyundai Sonata Cars & Trucks
How can i get a pin code for hyundai Elantra 2003 . please
contact ehyundai with the V.I.N and they should be able to help you.. i am presuming it is for the stereo.
Jun 30, 2009 | Hyundai Motor 2003 Elantra
Car Audio & Video Logo
21 people viewed this question
Top Hyundai Car Audio & Video Experts
David Burbee
David Burbee
Jude24
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
