Intel pentium g620 2.6ghz 3mb processor
I have a intel pentium g620 2.6ghz 3mb processor, my internet runs slow. i know its not the network coverage, cause i used a laptop with same modem, and it worked fine. I heard, if I upgrade the processor on my desktop my internet will work faster. is this true? kubenmd@gmail.com
    Master:
  • 366 Answers
Upgrading your processor will not speed up your internet only the overall speed of your system. try antivirus scan or remove any spamware/ clean out temporary internet files. look at ways to speed up your browser. Consider increasing your internet speed via your internet/broadband provider.
Posted on Dec 30, 2013
4 Suggested Answers
myob247
  • 1342 Answers
SOURCE: Vista...Running very slow
Have you installed Vista SP1 yet?
Posted on Apr 07, 2008
  • 16 Answers
SOURCE: slow running INTEL PENTIUM 3
Well abcopeland, you can add another ram (the easiest way). Do scan disk (to remove unnesassary file) & defragmentation. Check also weather your pc have been infected or not by installing a good anti virus.
Posted on Nov 15, 2008
ericram
  • 101 Answers
SOURCE: Upgrading IBM ThinkPad T20 Intel Pentium III to Intel Pentium 4
Patrick, I'm glad to see your enthusiasm to explore and expand on your computer knowledge. Unfortunately I have to be the first to let you know that in this case your ideas on upgrading your systems by simply changing the processors just won't work.
First of all a Pentium 4 (or Centrino, which is the mobile version) literally will not fit into any of the systems you mention. All CPUs are made in specific form factors to fit into different sockets. Most Pentium 4 processors were made for Socket 478 or 478B sockets, which mean they have 478 pins on a chip roughly an inch and a quarter square. The high number of pins allow more signals and data to be passed simultaneously to the motherboard, one way the speed of the CPU operations were increased. Pentium III and older Celerons were mainly socket 370 chips on a chip almost an inch and three quarters square. The lesser number of pins were aligned in six concentric rows with a blank central square. Pentium II and even older Celerons used Socket 7 and any of a half dozen other schemes and were often put on daughtercards to make them somewhat interchangeable. It would be like trying to put a square peg in a round hole.
They also make other forms, like socket 775, 939, and the newest AM2, all of which are pin-incompatible. In certain situations there are adapters that will let you put a newer CPU into an older socket but the specific upgrades you mention have no equivalent.
There are other engineering factors to be considered as well. Not all CPUs run on the same voltage. Many desktop motherboards have been designed that are adjustable either by selecting the operating speed with jumpers (old style) or by electrically sensing the optimum speed of the CPU. Then there are the memory and bus speeds. The CPU has to be able to interact with the memory so they must share a signal speed. This is the Front Side Bus. Older Pentium 4 CPUs were designed to use PC-133 memory but more powerful CPUs. certainly any in the 2.0GHz and up range, are designed for Double Data Rate (DDR), which is PC-2100 up to PC-3200. The pin configuration of the memory is different also to reflect and optimize the faster design. Of course there is now a DDR2 design and most recently DDR3. Core-Duos and Quads use the DDR2 and DDR3 type memory.
Another factor is heat. Faster CPUs run hotter. the system must be designed to accomodate and release the greater amount of heat generated, thus there are larger heatsinks and fans and more vent holes. Otherwise the CPU would start acting erratically and eventually burn out.
Things would be slightly different if you were talking AMD chips, as the socket 472 was much more versitile and could handle a wider range of CPUs and speed, from Duron to Sempron to Athlon XP, all because of the way AMD designed their chips. Of course, they too had to upgrade to surpass physical limitations, leading to the socket 754 and other newer designs.
Desktop machines are much more flexible to upgrade because of the space available and the fact they are designed with expansion slots. If you need a higher video card to run games, or more com ports to run extra printers or whatever, you can generally place a card in a slot to add the functionality. If you reach the design limits of a motherboard you can usually swap it out. Not so with laptops.
Laptops in particular are hard to upgrade because everything is integrated into or designed to plug into the motherboard, which has to fit the case properly like a jigsaw puzzle. This is not to say it is impossible to upgrade somewhat, but usually for laptops it means putting a faster CPU of the same form. Here is an example that is specifically for the IBM T40 laptop:
http://bsnugroho.com/t40upgrade.aspx
No, if you want to upgrade to Pentium 4 or Core Duo or Core Quad speed and performance, you will have to go out and buy a laptop.
Please do not let this discourage your enthusiasm. You share the spirit of the old school to push the limits that has made all of these computer evolutions possible. Consider formal training to round out your knowledge and to expose you to more within the field.
Posted on Dec 31, 2008
Lenovo v570 GHz upgrade?
Oh yeah!
From looking at the Datasheet just now, it shows the entire Processor lineup available;
http://www.lenovo.com/shop/americas/content/pdf/system_data/v570_tech_specs.pdf
A) Intel Pentium B950 - Dual Core - 2.10GHz, and 2MB of cache.
B) Intel Core i3 - 2330M - Dual Core - 2.20GHz, and 3MB of cache
C) Intel Core i5 - 2430M - Dual Core - 2.30GHz, and 3MB of cache
D) Intel Core i7 - 2630QM - Quad Core - 2.00GHz, and 6MB of cache
E) Intel Core i7 - 2670QM - Quad Core - 2.20GHz, and 6MB of cache
http://shop.lenovo.com/us/laptops/ideapad/v-series/v570
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#.22Sandy_Bridge.22_.2832_nm.29_2
http://en.wikipedia.org/wiki/List_of_Intel_Core_i3_microprocessors#.22Sandy_Bridge.22_.2832_nm.29_2
http://en.wikipedia.org/wiki/List_of_Intel_Core_i5_microprocessors#.22Sandy_Bridge.22_.2832_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Sandy_Bridge_.28Quad-Core.29.22_.2832_nm.29
Your laptop uses the Intel HM65 Mobile chipset, for the motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_i_Series_mobile_chipsets
Nehalem Architecture,
http://www.hardwaresecrets.com/article/535
Your CPU (Processor), and the ones listed; are based on the Sandy Bridge architecture.
The Nehalem architecture started the ball rolling.
The Sandy Bridge architecture is evolved from it.
NanoMeter - 1 Billionth of a Meter
Abbreviated as nm.
Architectural size went from 135nm, from Processors back in the old days; to 22nm now.
http://www.hardwaresecrets.com/article/Inside-the-Intel-Sandy-Bridge-Microarchitecture/1161
Plus the Intel Core i processors are a whole different 'ball of wax'.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | Computers & Internet
Does my TOSHIBA SATELLITE 2805-S301 have a way to go wireless?
No wireless on this laptop you would need to use a usb wireless adapter
roduct Details and Features Product MPN MPN
PS280U-ELCLOH Key Features Laptop Type
Mid-Size Laptop Use
Home Use Processor
Pentium III 650 MHz Hard Drive
10 GB Display
14.1 in. TFT Active Matrix Operating System
Microsoft Windows ME Weight
7.3 lb. Processor Processor Manufacturer
Intel Processor Type
Pentium III Processor Speed
650 MHz Motherboard Bus Speed
100 MHz Memory Installed RAM
128 MB Max Supported RAM
384 MB Installed Cache Memory
256 KB Hard Drive Hard Drive Capacity
10 GB CD / DVD CD / DVD Type
DVD-ROM Optical Drive Read Speed
8x (DVD) Other Drives Floppy Drive
3.5" 1.44 MB floppy Display Display Tech
TFT Active Matrix Screen Size
14.1 in. Video Installed Video Memory
8 MB Audio Audio Output Type
Sound card Operating System Operating System
Microsoft Windows ME Platform
PC Technical Features Input Method
Keyboard Networking Networking Type
Integrated Network Card Data Link Protocol
Ethernet • Fast Ethernet Modem Modem Type
Modem Analog Modulation Protocol
ITU V.90 Battery Battery Run Time
2 Hours Battery Technology
Lithium ion Dimensions Width
12.9 in. Depth
10.7 in. Height
1.5 in. Weight
7.3 lb. Warranty Warranty
1 Year Miscellaneous Product ID
20789390 Family Line
Toshiba Satellite
Jun 19, 2011 | Toshiba Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
Dell Latitude 1.6 GHz/512/40GB-processor speed seems to be stuck at 221 mhz regardless of what app I am running. Is there a way to adjust the speed of the processor? Or is the processor bad?
The processor is throttled by a process called speed step. This slows the CPU to save power. The same process is used when the processor overheats, and the system throttles to manage the heat production.
So the heatsink and cooling fan should be replaced as the first step in trying to resolve the process.
Jan 11, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Intel Pentium II Processor Upgrade
No, this highest the P-II went to was either 400 or 450 Mhz. Upgrading a thinkpad CPU may be difficult. Considering prices on used laptops now, I wouldn't think it would be worthwhile, either.
Neil
Feb 09, 2009 | Intel Pentium III , 866 MHz...
Slow running INTEL PENTIUM 3
First thing to do to speed up a computer even with this slow processor is to remove some unnecessary program installed on the computer, then run a good anti virus and anti malware software some Avast and Malwarebytes to make sure that not a virus or malware is causing this slow computer and the best thing to is to add up a Mermoy on your computer that will surely make it much faster....
Nov 09, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
May 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Missing drivers for compaq presario v2000 machine
SOLUTION!!!
**Even though your computer may SAY that it is a Presario V2000, it may have an entirely different product number for downloading drivers specific to your particular configuration.**
1) Look at the serial code on the back/bottom of your computer: there is a number starting with p/n (ex. p/nEX664UA#APL) This code identifies your computer beyond the V2000 label.
2) Go to the compaq/hp website: http://welcome.hp.com/country/us/en/welcome.html#Support
3) select "Download Drivers and software(and firmware)"
4) THEN, enter your P/N Instead of "Presario V2000" into the product name/number box, and hit enter.
Select your operating system, and you will be redirected to a page listing all the necessary drivers for your model.
On the left of your screen, you will see a box that says "your product" with a picture of a laptop, and a model number beneath it. THIS IS YOUR ACTUAL MODEL NUMBER (Mine was Compaq Presario V2610CA Notebook PC).
5) Download and install the drivers you need, and gappy geeking!!!
G33K_G1RL
May 08, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
