Oct. 10, 2017 - I have a 2000 land cruiser and my abs, active trac, vsc trac, vsc off, and brake light all came on at once. I have - Answered by a verified Toyota ...
2000Land Cruiser ... Below are some commonly found Toyota dashboard lights ... Electric Power Steering (EPS) Warning Light [1] ... TRAC OFF Indicator [1].
Toyota Run X
You should find the PS reservoir for your Run X in the same location as is shown in this video of the Toyota Corolla power steering reservoir. It is clearly shown in the video.
? 2:55 www.youtube.com/watch?v=mtQfJ31MLxk Oct 21, 2010 - Uploaded by 1A Auto Parts
Auto Repair: How Do I Check/Add Power Steering Fluid to MyCar or Truck? .... What type of power steering fluid could I use for my 2003 Ford Explorer? .... Toyota 4 Runner Steering Problem Returns - EricTheCarGuy ..
Do you need to replace an existing pump or is your car currently manual steering? If it is manual steering there will be more than just adding a pump. The actual steering rack is most likely different from a power steering unit so there would be multiple components required to convert. If your pump is faulty, you just need to disconnect the lines, remove the belt then remove the pump and install the new one. While you are doing that I would flush the old fluid out of the rack to increase life span of steering rack.
If you are saying the steering is difficult to turn you could have a blocked hose or a problem in the gearbox. Or something in the front suspension such as a faulty ball joint.
that symbol is for your tire preasure,its telling you that one of your tires are low, check all tire preasures, you can set to32 psi or look in manually sometimes they have you set them at 28psi but i always go to 32 psi. anyway theres a button on the lower left of steering wheel to reset or drive a few miles.also check your spare, hope this helps.
I have a power steering leak on my 1998 Toyota Camry. I have been using over the counter stop leaking fluids, but it has not helped. It leaks more during the cold weather as oppose to hot weather.
Deme
