Question about Dell 2007FPW UltraSharp 2007FP 20.1-inch Flat Panel LCD Monitor with Height-Adjustable Stand
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
    Scholar:
  • 47 Answers
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
Posted on Jun 06, 2009
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
How to connect dual monitors to docking station
one monitor you have onto laptop, second monitor connect to laptop connector for external monitor and in menu Start - Settings - Setting panels - "Icon - Viewing" and for this dialog window select folder "Settings" and configure secondary monitor
Apr 21, 2012 | IBM ThinkPad T40p 2373 Notebook
ThinkPad T410 Docking Station Not being Recognized
Change the BIOS to reflect output through dock(external Monitor) first.
Jan 05, 2012 | IBM Lenovo ThinkPad T410 Notebook PC
Hi, I connected my monitor and my ethernet cable to the dockingstation SD400V, But there is no connection at all. No internet access and no image on my monitor. Can you help me?
Hi
I had trouble with this Docking Station.
Use USB 3.0 and try this:
1) follow this instructions: http://support.euro.dell.com/support...l=pl&s=gen&cs=
2) restart, unplug docking station
3) install this software: http://www.displaylink.com/support/downloads.php, version 6.1
4) restart
5) plug docking station
After all, it should working.
In any questions, write: pawel_surowiec (at) o2 (dot) pl
Mar 30, 2011 | Kensington SD400V USB Docking Station with...
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Syncmaster 2333- connected fine to laptop on docking station for 3 months. Then all of a suddent it is causing my laptop to crash. laptop works on its own. Connected, the monitor shows my encryption...
Disconnect the monitor from the docking station and plug it directly in the laptop connector. If all is well it might be the docking station. I had one crash a computer and had to rebuild the operating system to make it work again.
Mar 09, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Laptyop D630 once undocked - trouble to conenct a projector ...
Basically you most likely have a corrupt hardware profile. Delete the profile for docked and try again, this normally works.....Mark
Aug 19, 2009 | Dell Latitude D600 Notebook
Buzzing noise coming out of television when i plug in power cord
Right, the problem is caused by the earthing of the power supply.
You need a box, which isolates the earth from the laptop to the television, known as an Isolation Transformer. This goes in between your laptop and television, and removes the cause of the hum.
The other option is entirely at your own risk, as you're dealing with mains electricity, however, cover the earth pin with some insulation tape, thus stopping the power supply from earthing. Keep a close eye on the condition of your power supply and cable, as you will not be protected against shock if a fault should develop.
The same problem exists with Acer Laptops, as I have one, and use an isolation box when I want to play music in venues from my Laptop.
Mar 04, 2009 | InFocus X1 Multimedia Projector
Infocus projector connected to Toshiba laptop
The sequence is fn first then f5 simultaneously then release. However the problem may be the resolution setting on your computer's 2nd monitor output may be out of range (too High) for the 4805 Start with 1024X768 and see if that works.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
Dec 15, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
