Question about Cell Phones
Parrot wiring diagram CK3100N
Fitting instructions
3 Suggested Answers
SOURCE: Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Posted on Feb 18, 2009
  • 95 Answers
SOURCE: fitting hands free car kit Parrot CK3000 Evolution
Just make a look:
http://www.parrot.com/uk/support/onlinehelpguides/parrotck3000evolution
Posted on Mar 26, 2010
Parrot doesn't pair.
according to the wiring diagram the red wire goes to full time hot [+] and the orange wire connects to a switched hot [+]. See page 7 on this link: http://parrotcontact.parrot.com/website/user-guides/download-user-guides.php?pdf=ck3100/CK3100_Quick-start-guide_UK-FR-SP-DE-IT-NL-PT.pdf .
Aug 18, 2015 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Will not connect
it sounds like it has been wired wrong, no signal is normally the result of the bad wiring or jump starting. you will need to have the software upgraded but it can only be done via update cable, i would go to parrot.com and find you nearest engineer, they will do this and check out the fitting.
Apr 27, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Connected Parrot Ck3100 in Toyota Rav4 with Alpine 5897 aftermarket head unit. Tapped the Parrot harness into the speaker wire between the Front driver side speaker and amp, per instructions and phone...
First, you will have to ensure that the vehicle doesn't have an amplified system build in it. Cause in that case the kit should use the two wires line in and line out and check behind the autoradio if you have the entries line in line out. (with this solution, no accessibility with the mute when you have the radio and you receive a call).
But the general idea is to ensure about the vehicle system build in it, cause with an amplified system, you have to avoid it to passing the sound directly to the speakers. (may be wires to wires or a specific harness which is taking acount of it).
Feb 27, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I have a new parrot ck3100 and i am fitting it to passat 2002 on iso connection the screen is lighting up but showing no texts or anything showing were am i going wrong??
try the connection at the botton of the screen to see if it in properly. if it is then you will need to write new software into the parrot.
Dec 21, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Cell Phones Logo
98 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
