Question about Sony Video Game Consoles & Games
Hdmi not working on tv
Hdmi on tv not working for xbox one
Original xbox system
How do you have your Xbox connected to your TV? Through an HDMI cable? Are any other components involved, such as a Home Theater system, etc? If you have your Xbox going directly into your TV, you should be able to select the input (IE: HDMI 2) on the TV, then power on your Xbox and be ready to go.
I hope this helps!
Oct 26, 2013 | Insignia Televison & Video
I recently bought an HDMI cable for my xbox 360 (the new type, i don't know if it has a name but its the one with the touch sensitive power button), and when I plug the cable into the xbox and the tv...
Sorry to hear about your trouble. You elimanted the cable as a potential problem so that is good. You are left with a couple of options that might be causing the problem.
-Bad HDMI port on the XBOX
-Bad HDMI port on the TV
-Incorrect TV settings
On the TV, you want to make sure you set it to the HDMI input when you are using HDMI, but I assume you already do this and most newer TV's will auto adjust to HDMI when the xbox is turned on. Always good to double check.
The easiest way to narrow the problem down further would be to test the hdmi connection with another TV. If the xbox works on another TV then you narrowed the problem down to the TV and will need to repair the TV either through warranty support, by yourself or via a TV repair man. If the xbox has the same trouble on a different TV then you know the problem is with the XBOX and you can contact Microsoft Xbox support for repairs.
Let me know if you have any questions.
Regards,
G33k
Jul 05, 2011 | Microsoft Xbox 360 Console
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Which cable do i need to get my xbox to work on my HD tv
any will work asl long as your tv has the inputs available. but the _2_ that work the best i know personally is hdmi first and foremost. then your component cable (red, green, blue). i used them both on hd tv's and hdmi by far is the best. but if you have a vga (computer hookup) on your tv, i suggest trying the xbox vga cable second just as good as hdmi but the audio cables will hookup to another spot on the back of the tv. hope this helps.
May 10, 2010 | Microsoft Xbox 360 Console
I can't get my Xbox 360 to work over HDMI anymore, but other HDMI devices work and the Xbox 360 also works with other TVs over HDMI.
Reset your TV, try unplugging it for a while, if that doesn't help, try restoring or resetting it to defaults, there should be a function for that somewhere in the menus of the TV. that should solve the issue, if it still remains, check the cables and if possible try another hdmi port.
Nov 10, 2009 | Televison & Video
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
Hdmi - out of range
If your hdmi cord is good, and you are going from xbox to tv via hdmi , make sure you have your input on input 1. Hdmi ports are usually by default set to work in the first input of any tv or monitor.
Apr 12, 2009 | Televison & Video
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
