Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
I have an Amana afd2535debve refrigerator that's just over one year old. Suddenly, the refrigerator is not cooling. I tried to reboot it but that didn't work. I hear a fan sound all the time, but it seems the compressor isn't coming on. I turned it up to the max, but no luck. All the lights work and freezer works fine. Thanks.Ours is over two years old and we just incurred this problem about three to four weks ago. In addition to bobfrommy's input I just noticed that the center post attached to the laft door and colapses behind the right door, is super hot to the touch. JR LaPorte, Peoria, AZ
  • 1 more comment
  • jr2423 May 20, 2009
    Thank you for your input. All seals are good. The vent appears to be open. I need to check the fan. Does the defrost circuit control power to the fan on this model? (AFD2535DEB) (Code 12)
  • jr2423 May 21, 2009
    Ok. So it would be safe to asume then, if the compressor and the compressor fan are working (as indicated by the freezer doing its job to keep its contens frozen) the eveporator fan motor is most likely the part I need to concentrate on?
  • jr2423 Jun 02, 2009
    The eveporator fan was the problem. The refrigerator works again. Thank you for the help.
    Sergeant:
    Champion:
  • 219 Answers
I will advice u to replace the eveporator fan motor. It will fix ur problem.
Thanks!
Sandy
Posted on May 22, 2009
    Brigadier General:
  • 3,917 Answers
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators )
Also please read through the suggestion in the webiste provided bellow:
http://www.applianceaid.com/frig_notcold.html
Thank You
Posted on May 19, 2009
  • e-Guru
    e-Guru May 20, 2009
    Yes .
    Fans
    Normally the interior evaporator and exterior (if present) condenser fan motors should run whenever the compressor is running and vise versa. If the timer is stopping operation of the cooling system, neither the fans nor compressor should usually be running at that time.
    If you are interested on how the defrost works please read through this article:
    http://www.appliance411.com/faq/howdefro...
    Thank You
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
Have a 17yr old amana energy saver frig. freezer on bottom. freezer works fine, but no cooling in refrig.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Amana Refrigerators
There is a strong acrid odour coming from my Amana refrigerator. This frig is 15 years old and has a top freezer.
It may be a refrigerant leak in the coil and it will stop working soon. When this happens it's time for a new box. 15 years is a good run.
A new coil could cost as much as a new frig and that's without labor cost.
I hope this helps
Aug 23, 2010 | Amana Refrigerators
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper....
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Aug 07, 2010 | Amana ARS2464B Side by Side Refrigerator
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
5 year old Amana bottom freezer. No cooling because compressor not working. Technician tried a starter but it short circuited. Now fridge is off. Worth buying new compressor or a new frig? Is this a...
you can have the compressor replaced for around 500usd on the norm. that would be the most inexpensive way to go compared to a new unit , it will come with a 90 day-1 year warranty.
Phil
Jun 10, 2009 | GE GTH18KBR Top Freezer Refrigerator
Freezer works but bottom of frig wont cool.
check to make sure nothing is blocking door from closing all the way
Jan 18, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
216 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
