Question about Sony Dream Home Theater System, DAV-DZ120 System
Sony Bravia 40 inch tv looking for part Sony A3810M
Sony A3810M
SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
Posted on Apr 27, 2008
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
  • 148 Answers
SOURCE: Red Flashing power light on Sony Bravia 40 in tv
Hi there, your problem is that your powerboard is overheating due to poor capacitors. When you shut it off it cools and lets itself turn back on a few minutes later. Your post has been a while, so you might have lost the unit already. If you place a fan (any type house fan) as close as possible to the back of the tv and turn it on medium (at least) it might keep the tv cool enough to funtion indefinitly....If my advise is to late already then follow this guide I wrote on how to diagnose and repari your tv..Good luck and if this post helped you (or not ) then please rate, thank you!
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
Posted on Feb 03, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: my sony bravia 40 inch tv, almost half the screen
Does it look like the bands in the picture? it is defective panel.d817bda.jpg
Posted on Apr 21, 2010
Testimonial: "it's like that, but with a shatter/spider web pattern in the corner. an engineer said it was caused by impact damge - but this isn't the case. if we use the tv now, it just spreads and gets worse"
Sony activation code
I cant get the activation code from my tv to link ... - Sony
https://community.sony.co.uk/t5/other-tvs/i...activation-code...sony/.../299647
i follow the instructions:- press home button on the remote control, then navigate to sony entertainment network. Select link an account then the activation code should be displayed, this then is to be typed into the activate an hd tv on the entertainment network web site.
How to get the Sony Entertainment Network activat... - the Community
https://community.sony.com/t5/4K-Ultra-HD-TV/...Sony...activation.../487967 Feb 8, 2015 - Perform the steps below to locate the registration code on the Internet video device. Using the supplied remote control, press HOME. Use the up arrow or down arrow button to select Applications. Select Sony Entertainment Network icon and press OK. Select Activate Enhanced Feature and press OK. Select Open.
How to activate a HDTV/Sony Home Entertainment System/Sony Blu ...
https://www.playstation.com/...activation-deactivation/activating-hdtv-sony-home-ent... Apr 10, 2017 - Find out how to activate your HDTV/Sony Home Entertainment ... on the device menu and find [Link an Account] to get your activation code.
SONY EU ' Support - How do I access the Sony Entertainment ...
sony-eur-eu-en-web--eur.custhelp.com/.../how-do-i-access-the-sony-entertainment-ne... Write down the device activation code. Using a computer or other Internet browser-capable device, log into the PlayStation Network site by dragging the cursor ... sony activation code Google Search
Jul 19, 2017 | Sony Computers & Internet
Tip
Convert/Import Sony DCR-SX/SR/HC/DVD Series to Mac, iMovie, FCP
As we known, Sony DCR series camcorder includes Sony DCR-SX, Sony DCR-SR, Sony DCR-HC, Sony DCR-DVD, Sony DCR-TRV, Sony DCR-VX, etc, and most of Sony DCR camcorders record video in SD MPEG-2 such as some Sony DCR-SX series, Sony DCR-SR series, Sony DCR-DVD series.
Some Popular Sony DCR Camcorder Series in the following:
Sony DCR-SR: SR40, SR42, SR60, SR68, SR82, SR87, SR100, SR200, SR300, SR45E,SR65E, SR87E, SR85E, SR220E, etc.
Sony DCR-SX: SX40, SX44, SX60, SX63, SX83, SX34E, SX40E, SX43E, SX46E, SX60E, etc.
Sony DCR-HC: HC35, HC26, HC28, HC62, HC40, HC21, HC52, HC24E, HC38E, HC54E, etc.
Sony DCR-DVD: DVD650, DVD108, DVD92, DVD850, DVD403, DVD505, DVD610E, DVD710E, etc.
Due to Sony DCR video cannot be directly imported to iMovie, Quicktime, iTunes, FCP, Adobe Premiere Pro and some other popular devices, if you want to import your Sony DCR Handycam SD video to Mac for enjoying or further editing with iMovie, FCP, FCE, etc, the first step for you to do is to convert these Sony SD video to MOV, MP4 for Mac, then you can import converted Sony DCR video to iMovie, Quicktime, iTunes, FCP on Mac for enjoying or editing.
To convert Sony DCR series video to Mac, Sony DCR Video Converter for Mac is the best software to transfer these Sony DCR SD MPEG-2 video, Sony AVCHD MTS, M2TS files, and some other camcorder videos to MOV, MP4, MPEG, 3GP, M4V, etc on Mac. Besides, you can also convert and import Sony DCR SD video to iPad, iPod, iPhones (including iPhone4), PSP, Blackberry, and other mobile players.
How to Convert Sony DCR video to Mac OS for further editing with iMovie, FCP, etc?
Step1: Add Sony DCR Video on Mac
Click "Add File" to upload your chosen Sony DCR video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step3: Convert Sony DCR Video to Mac OS
Press the "Start" button to convert Sony DCR SD video or AVCHD MTS/M2TS files to Mac. After conversion finished, you can enjoy converted Sony DCR video on Mac or edit these videos with iMovie, FCP, FCE, iDVD, etc.
Related: How to Convert and Edit Canon VIXIA HF Series to Mac?
How to Convert and Edit Panasonic HDC Series to Mac OS?
on Oct 26, 2010 | Computers & Internet
Sony N50 pop up flash has a broken cable . It pops up ok but doesn't flash
My advice is to have it serviced professionally
  1. Henry's - Sony Digital Cameras - Canada's Greatest Camera Store‎
    Adwww.henrys.com/Sony-Cameras/Digital-Cameras This ad is based on your current search terms. Visit Google's Why This Ad page to learn more or opt out. Find The Best Discounts On Sony Digital Cameras At Henry's Canada - Shop Today! Droneopraphy Headquarters · Free Shipping Eligibility · Capture Your Memories
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
g-img{display:block}._WCg{display:block;border:0;position:relative} Search Results
SONY Camera Repair (Digital and Video) ' Authorized Repair Center ...
www.precisioncamera.com/sony-camera-repair.html
  1. Cached
  2. Similar
SONY digital cameras and video cameras can be repaired economically.
Sony eSupport - Electronics - Service & Repair
https://esupport.sony.com/CA/p/service.pl
  1. Cached
  2. Similar
Sony eSupport - Service & Repair. ... Headphones · Walkman Digital Music Players · Wireless Speakers · High-Resolution Audio · View All ... Video Cameras>.
Send in Repair - Sony
https://pro.sony.com > Home > Support
  1. Cached
  2. Similar
Click here for Sony Security Products Repair and Contact Information ... Arm Assembly; Brake Assembly; Digital Hour Timer; Upper Drum Assembly; Slip Ring ...
Sony Camera Repair - iFixit
https://www.ifixit.com/Device/Sony_Camera
  1. Cached
  2. Similar
Repair guides for a large selection of Sony digital and film cameras.Sony Camera troubleshooting, repair, and service manuals.
However, here are some DIY solutions
Sony Digital Cameras Google Search
Oct 30, 2016 | Sony Cameras
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
It is a Power Supply board and is a part shared with some Sony televisions.
Sony Power Supply Board A1300319A KV32HS500 ... - eBay
www.ebay.com > ... > TV Boards, Parts & Components Sony Power Supply Board, A1300319A, KV32HS500, KV34XBR800... (280925870381) in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio ...
Sony A1300319A SONY A-1300-319-A COMPLETE PC D ...
www.amazon.com/Sony-A1300319A-A-1300-319-A...BOARD/.../B001... THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONY TELEVISIONS. PLEASE FOLLOW THE LINK ABOVE FOR ...
Sony A-1300-319-A D Board, Complete - Encompass Parts
https://www.encompassparts.com/.../Sony/A-1300-319-A/D_Board,_Co... Image, Manufacturer, Part Number, Description, In Stock, Part Price. Pts Modules, A-1300-319-A, Sony - D Board (Deflection & Power), 271.90 ...
A1300319A, A-1300-319-A Sony TV Module, D
www.tristatemodule.com/A1300319A-A-1300-319-A-Sony.../a1300319... US$148.00 Part Number: A1300319A. Board Numbers: . TV Models: KV-32HS500, ... Home > TV Parts > PC Board > A1300319A, A-1300-319-A Sony TV Module, D ...
Jan 30, 2016 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Drivers webcam for sony vaio ar520, windows7
Please install the Sony Shared Library and then install the Original Sony Visual Communication Camera to resolve the Camera issue. If you installed Windows 7 32 bit Operating System also, you can try installing the same Driver as the Drivers for Windows Vista should work under Windows 7 Operating System.
Sony Shared Library is the System component which makes the installation of the other Drivers compatible with the Computer.
Sony Shared Library:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNAR520E&upd_id=2653&os_id=28
Sony Camera Driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNAR520E&upd_id=2850&os_id=28
All the Drivers:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNAR520E
Good Luck!!!
Jul 06, 2010 | Sony Computers & Internet
Desperate need for manual
hi,
see if the sony cam manual you need was on this list:
The Sony DCR-TRV480 and DCR-TRV380 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV480.PDF
The Sony DCR-TRV460 and DCR-TRV361 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV460.PDF
The Sony DCR-TRV280 Digital8 Manual which also covers the Hi8 CCD-TRV138 and CCD-TRV338 can be downloaded at:
http://www.docs.sony.com/release/DCRTRV280.PDF
The Sony DCR-TRV260 and DCR-TRV265 Digital8 Manual which also covers the Hi8 CCD-TRV128, CCD-TRV228 CCD-TRV328 and CCD-TRV428 can be downloaded at:
http://www.docs.sony.com/release/DCRTRV260.PDF
The Sony DCR-TRV130 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV130.PDF
The Sony DCR-TRV240, DCR-TRV340, DCR-TRV740 and DCR-TRV840 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV840.PDF
Jun 02, 2009 | Sony Video Cameras
Sony Handycam HDD error
no solution...u need to go to sony service center and replace the HDD. It will cost u around 8K.
Poor camera ....
Don't suggest sony to anybody else.
Mar 20, 2009 | Sony Handycam DCR-SR40 Camcorder
129 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
