Question about SanDisk Electronics - Others
My sandisk when plugged in light blinks..pc says device installed..then nothing. usually when i go to MY COMPUTER it would show word CRUZER nd then i go ahead and send pictures to it..but this new one
Not much more i can add..when i plug in old sandisk the cruzer emblem pops up and i know its there and ready to do pics this new one doesnt do that. why?
    Sergeant:
  • 376 Answers
Is the new drive the same as the old one? Perhaps it needs formatting.
Posted on Jun 22, 2014
Ryan5443
  • 336 Answers
SOURCE: i have a 4gb cruzer flash drive and its not working
Okay. Try putting it in on the back of your computer and tell me if it lights up at all, even if it flashes once.
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Posted on May 12, 2009
  • 76 Answers
SOURCE: My pc doesn't recognize my Cruzer USB 2.0 Flash drive
Try a different USB port, sometimes they can get damaged and stop working. Also, Check out this link and try the options listed there: http://kb.sandisk.com/app/answers/detail/a_id/10/kw/usb%20flash%20drive/r_id/101834
Posted on Sep 15, 2009
bob_computer
  • 3153 Answers
SOURCE: My flash drive wont do anything when i plug it to my computer.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
  • 597 Answers
SOURCE: i have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Posted on Sep 30, 2009
Testimonial: "do you have any idea what could have caused this? for one minute it was working, then it's broke.. :("
  • 8064 Answers
SOURCE: unknown device
Plug it through different USB ports, even a USB Hub, or on a different computer. Sometimes rebooting solves the problem. I suspect it is a USB problem, especially on laptops with a small number of USB ports.
I have given mine up as dead several times, but it always comes back up gain.
Hope it helps.
Posted on Nov 14, 2009
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
How do you get this thing to work. We have Windows Vista and want to save our pictures but we have never use one and we are stuck. We put the device in j drive and thats all we got. Help
1.plug your SanDisk Cruzer on your pC.
2. wait for the installation to finish(installation usually starts by itself )
3.go to my computer and try to find your device
4. if you found the device you can know start transferring your pictures,,
Jun 18, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computer is not detecting the drive?
right click on "My Computer/Computer" then go to Manage then go to Disk management check to see if the drive shows there if so right click on it and navigate the tabs until you see Assign a drive letter select a letter that is not in use, i usually use p-v because its use is rare. If it does not show in Disk manager check device manager and see if its under Usb/Unknown/Drives/removable storage/ or other devices if its not there then your device may be damaged or your port may not be installed properly/damaged
Jul 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I plug in the sundisk cruzer 2.0 GB USB device and all it does is blink. It will not show up on my computer for the drive.
Hello
If the computer recognize that there is a device plugged into the system, then just try to plug the flashdrive into another port at the back of your case.
If the computer does not recognize that there is a device plugged in, there is a problem with your flash drive. It still gets power from the computer(Bliking light), but there is no data transfer between computer and flash drive.
If it is still under warrenty, send the flash in for repairs(presuming that your USB ports work), otherwise try and see if it works on a other computer. If it does, the the problem is with the USB ports on your computer. I really hope this can be of help.
Best regards
Andrea
Oct 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I plug the sandisk in to the computer & it doesn't light up nor make the noise. I plugged another one in just to make sure it wasn't the USB drive, the other one worked like a champ. What do I have to...
kindly go to control pannel and and see that removable media device is configured and also check the drivers for it in device manager to ensure that fault is not on sofware end ,if this does not show and green......then try changing the port you insert it into hopefully this will fix the issue else consult local hardware shop for recovery of the data in it
and also get it replace if under warranty
thanks and regards
kindly rate this solution
Oct 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 4GB thumb drive not recognized by my computer
Try any other computer but not open drive only see if they can read it. Also change USB port, sometimes some ports dont accept devices. Also check for latest antivirus software last such case viruses dont let me read any of my USB drives. If driver works to oter PC then you have virus.
Aug 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My copmputer wont let me install a sandisk cruzer
Check you have your chipset drivers installed if not go to manufacture's website and download from there what Operating System do you have?Right click over my computer drop down to properties,click on hardware,click on device manager and make sure there is no yellow explanation points and see that all drivers are installed correctly.Have you plugged the sandisk into another computer to see if it is accessible on another machine?
Aug 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Mar 10, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
