Question about Exercise & Fitness
Kettler treadmill um 678X err4
I bought the above. After assembly it worked fine for a short time, but then a "err 4" appeared, and we checked the connections, powered it off and on, tried the reset buttom, but with no luck.
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
  • 64 Answers
SOURCE: Life Fitness T3 treadmill won't turn on. Power
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Posted on Nov 17, 2009
zeronullity
  • 71 Answers
SOURCE: ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Posted on Nov 16, 2011
ercupa190
  • 12223 Answers
SOURCE: Kettler axos Cross p crosstrainer. First Time use.
adjust the REED switch see the diagram, clean, and tigh the wires connector very well.
2) tight the ribbon cables, clean it,very well
3) tight the display board connector vs lower board connector
Try again. 4) If this not function Try to RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on Sep 01, 2012
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
Kettler axos Cross p crosstrainer. First Time use. Err4 On Display, no Reaktion On keys. What can i do?
God bless you
Aug 31, 2012 | Exercise & Fitness
Kettler alpha xl treadmill
Kettler alpha xl laufband typ 7894-600 err3
/uploads/images/kettler-alpha-xl-treadmill-34874487-1-1.jpg
Aug 01, 2012 | Exercise & Fitness
TX3 folding treadmill. switch on says ERR how to fix is the question>
This is probably a 1) faulty speed sensor or
2)the speed sensor is not plugged in properly.
3)Its also possibly a faulty motor control board or
4) lower board. T
he error codes will differ between makes and models but could be e1.
However if you send the complete information, if can not fix you treadmill, how model, mark, serial number, I can handle more specific.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 16, 2011 | Kettler TX3 Folding Treadmill
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Exercise & Fitness Logo
372 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
