Question about HP LaserJet M5035 MFP Printer
HP Laserjet m5035 blue line when colour scanning to email
Blue line through scans to email/network from adf only, when scanned in colour. Doesn't happen on flatbed, and doesn't happen when doing am adf scan in black and white. Any ideas?
    Sergeant:
    Champion:
  • 317 Answers
Try checking for debris or other on the ADF itself and below on the prism. The ADF cover glass could be spotless, but if there is a speck on the prism itself, this could cause the actual prism to send a line while scanning.
Posted on Dec 30, 2013
4 Suggested Answers
SOURCE: HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Posted on Dec 20, 2008
  • 141 Answers
SOURCE: Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Posted on Aug 04, 2009
SOURCE: HP Digital Sender 9250C Color Scan Problem
We purchased 2 HP scanners 9250C and have the same issue. Send it back to HP, they make some correction for firmware, after 1 day, everything is ok.
Posted on Apr 09, 2011
Laserjet m5035 line when colour scanning
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
Can i scan to email with m5035
You can, but you need to configure
Sep 05, 2011 | HP® LaserJet M5035 MFP Laser...
When document is scanned to email--email copy shows a large yellow band down the left side of the document--shows everytime--replaced toner--cleaned everything--willl not go away
You need to isolate the problem first. Try scanning from the ADF and then scanning by placing the document on the glass. If the error shows on both then it is likley you have an issue with the scanner. If it only shows on the ADF copy then most likley the glass is dirty and needs to be cleaned. Curious as to why you replaced the toners to resolve a scanning issue? The scanner does not use any of the toner system, it is purely electronic.
Mar 22, 2011 | HP LaserJet 2840 All-In-One Printer
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Aug 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
HP LaserJet M5035 MFP Printer Logo
240 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
