Question about HP LaserJet M5035 MFP Printer
Laserjet m5035 line when colour scanning
Getting a blue line through scanned jobs. Happens only when scanning in colour to email/file from the ADF. If you scan from the flat bed, it is fine. If you scan from ADF in black & white is also fine.
  • Steven Crawford
    Steven Crawford Dec 30, 2013
    I should add that I have cleaned the adf glass and white back plate, both are spotless.
    Sergeant:
    Champion:
  • 317 Answers
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
Posted on Dec 30, 2013
MUKHTAR
  • 2017 Answers
SOURCE: Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Posted on Nov 16, 2007
SOURCE: Scanner Problem
The Laserjet 3050/3052/3055/3390/3392 FULL software version 4.0 (27 Mar 2007) for Windows Vista. Check out HP's download page or click the following for the US & EU version: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=114078
0&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
This should fix all your problems
Posted on Aug 27, 2008
  • 628 Answers
SOURCE: stripes on scanned photo
Do copies come out the same? How about when you print? If you get the stripes whenever the printer prints from the computer or copies, then you probably have a bad ink cartridge. If you get it only when you make copies or scan, then check for dirt on the scan glass. Clean it anyway with some commercial glass cleaner. See if that works.
Posted on Dec 01, 2008
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
SOURCE: HP 9250C: 1st page scans fine, following pages are blue
calibrate the scanner
Posted on Jun 22, 2009
Please insert your originals into the automatic document feeder hp 3052
It is looking for a document to scan. Either a copy job was started and interrupted or the device is not sensing a document in the adf. If scanning, ensure document is flushed and is fully inserted. If not scanning, cancel all jobs. If scanning and document is flush and fully inserted, check sensor/flag which may need replacement if all else is good.
Feb 21, 2015 | HP LaserJet 3052 All-In-One Printer
HP Laserjet m5035 blue line when colour scanning to email
Try checking for debris or other on the ADF itself and below on the prism. The ADF cover glass could be spotless, but if there is a speck on the prism itself, this could cause the actual prism to send a line while scanning.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
Can i scan to email with m5035
You can, but you need to configure
Sep 05, 2011 | HP® LaserJet M5035 MFP Laser...
When document is scanned to email--email copy shows a large yellow band down the left side of the document--shows everytime--replaced toner--cleaned everything--willl not go away
You need to isolate the problem first. Try scanning from the ADF and then scanning by placing the document on the glass. If the error shows on both then it is likley you have an issue with the scanner. If it only shows on the ADF copy then most likley the glass is dirty and needs to be cleaned. Curious as to why you replaced the toners to resolve a scanning issue? The scanner does not use any of the toner system, it is purely electronic.
Mar 22, 2011 | HP LaserJet 2840 All-In-One Printer
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Bell & Howell 2000d fb adf tray will not go down after scanning
It may be the clutch on the left side of the ADF. there are 2 there, one does the pick roller the other the tray. you could try swapping them over and see what happens.
also the sensor sometimes sees the underside of the top of the ADF and thinks its more paper, therefore keeping the tray up. try running a perment black pen around the inside of the hole in the tray where you put the paper to stop too much light getting in. (dont colour in the sensor itself though!)
Sep 04, 2009 | Bell & Howell FB Series 2000D Flatbed...
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Aug 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
HP LaserJet M5035 MFP Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
