Question about Remington R5130
Not cutting although inside is turning and beard trim works
Where is serial number on philips BEARD TRIMMER QT4019?
Remove comb from the unit. Look for a 4 digit number on the backside of the trimmer between the red strip(the adjustment ring) and the cutting blade
Aug 21, 2012 | Car Audio & Video
Need blades and charger
Hi, I also have this groomer and I loved it, Used for a long time to trim my beard. I lost the 3mm blade but I have everything else, the blades, the charger, the trimmer of course and even the cleaning brush and the instructions manual. If you are interested let me know, I'm willing to let it go. My email is albertojquintero@yahoo.com
Feb 19, 2012 | Sharper Image Ultra Groomer SM400 Beard...
On a Wahl Beard Trimmer 9876-536 -- what's the button on the side of the trimmer for?
The button info requested is almost 2 years old, but on my trimmer the button to the left of the power swt on the side is to lock the trimmer blade in the front or rear position. It is kinda weak and you can still move the blade if you push it. (I do seem to have the same one shown in the picture here.)
Later!
The Shadow
Nov 17, 2010 | Wahl 9876-500 Beard Trimmer
Trimmer humming but not cutting
use new battery if it used with battery..
but if it used with electricity then motor inside has gone bad
May 28, 2010 | Andis 04710 Beard Trimmer
Should i trim my beard upwards or downwards??
After or during showering, when your skin is still moist and pores still open, shave in the direction of the hair growth. This is different for different people -- not everyone has the same patter of hair growth, so there is no one direction to shave in. This is the same advice for ladies who shave their legs and such, so that's how I know. If you use an electric razor, the direction may not matter.
Aug 06, 2009 | Wahl 9916-800 Groomsman Beard Trimmer
Need a manual
im having problems changing the trim head
Jul 12, 2009 | Conair Deluxe Rechargeable Beard &...
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
DOES NOT CHARGE
If you still have it I have one I dropped. The body is still fine, and the batteries charge. A piece broke off inside the cutting blades. Let me know if I can help. Thank You, Jeff
Jan 15, 2009 | Norelco G270 Beard Trimmer
Remington R5130 Logo
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
